Error Code DTC 147
  • JDFugit
    • Jul 2022
    • 2
    • Cashiers
    • 2022 Super Air Nautique G23
    Error Code DTC 147
    Just got this error code on 2022 Super Air Nautique G23:
    DTC 147: ECM CAN COMMUNICATION ERROR. (LOSS OF CAN) CHECK EMERGENCY CUT-OFF SWITCH.
    Anyone have any experience with this?
  • FMSKI
    • Aug 2010
    • 244
    • Sproat Lake
    • 07 SV211 Ex330 Ski 'n Surf Sold (Ski 200, TSC1, 2001)
    In my Range Rover That means the serial network, aka CANBUS cannot comm with your kill switch unit presumably. So i'd check the connections to that unit, perhaps it's fiber-optic if they are slick.
    • Elkoman
      • Aug 2022
      • 1
      • AB
      • Nautique G23
      Hey there JDFugit,
      I have the same DTC 147 error message which you encountered showing up on my rig (also have a 2022 G23). Did you get it resolved by chance? Any help is appreciated.
      Thanks!
      • jbd32
        • Nov 2018
        • 5
        • Leeds, al
        • 2016 Nautique G23
        hello! its more than likely the plug on your dead man switch. pull the helm control pad up and find the plug where your dead man switch hooks to harness and mess with it, squeeze it you will hear the fuel pump click on and off and the volts on dash change. I butt spliced mine together and good to go. Nautique used deutsch connectors everywhere else and use some cheap connecter there. good luck!
        • mlange
          • 98
          • Oconomowoc, WI
          • 2012 SN 200 Mapple Icon Edition
          I don't see that DTC documented in the PCM Diagnostic Service Manual.
          • Miamiboat
            • Jul 2023
            • 2
            • Miami fl
            • Nautique g23
            Hi, did you get your boat fixed? If so please help I have the same problem. Thank you.
            • Miamiboat
              • Jul 2023
              • 2
              • Miami fl
              • Nautique g23
              Originally posted by Elkoman View Post
              Hey there JDFugit,
              Thanks!
              me too, and don’t know what’s the problem, please let me know if you fixed yours.
              thank you
              • Maksim.N.
                • Nov 2023
                • 18
                • WA
                • 2022 Nautique G23 ZZ6
                Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
                Hi! What was the problem, did you fix it?
                • Maksim.N.
                  • Nov 2023
                  • 18
                  • WA
                  I have this message DTC147
                  • Maksim.N.
                    • Nov 2023
                    • 18
                    • WA
                    Hello you fix it and it was something easy. Can you share your experience how to fix that problem?
                    • Maksim.N.
                      • Nov 2023
                      • 18
                      • WA
                      Any body can help me with code DTC 147. What should I check or pay attention to?
                      • Maksim.N.
                        • Nov 2023
                        • 18
                        • WA
                        Click image for larger version  Name:	20250809_170453.jpg Views:	0 Size:	352.7 KB ID:	686769 Click image for larger version  Name:	20250809_170625.jpg Views:	0 Size:	282.7 KB ID:	686767 Good news, I've solved the problem. ECM fuse showed 3.4V. The wire (power supply side) had a loose/bad connection. I put a 12v wire from the nearest fuse to the ECM fuse and the ignition started to work again. I will start trying to find the bad wire this weekend. If you guys know where the bad wire is located at, let me know to save my time, want to go surfing Thanks.
                        • Maksim.N.
                          • Nov 2023
                          • 18
                          • WA
ID:	686762 Click image for larger version  Name:	20250809_173737.jpg Views:	3 Size:	317.4 KB ID:	686760 I traced the bad red wire to the battery switch box, 15Amp Circuit Breakers with Push Button Reset, the problem was in the fuse which was causing the loose connection.
