I have a 2006 SV211. In 2020 I was having transmission problems and ultimately had to replace it at the dealer ($$$). Everything has been OK for a couple of seasons, but about a week ago I was doing routine maintenance with the boat in the garage, and dropped a tool in the bottom of the bilge (we've all done that). While retrieving it I happened to shine a flashlight towards the front of the boat between the engine and transmission and notice that I could clearly see the flywheel and ring gear. It looked like there where holes to mount a cover but the cover was not fitted. My immediate conclusion was that the bozo that replaced the transmission forgot to put the cover back on.
But when I called the dealer they said that some mid-2000 year Nautiques did not have this cover fitted. Is that right?? Seems like if significant water got into the bilge it would slosh into the "bellhousing" or whatever the marine equivalent is. That can't be good. The flywheel and ring gear had significant surface rust.
Thoughts?
Thoughts?
