Gt-40 oil leak
  • Airnautique1999
    • Jan 2022
    • 4
    • Gold coast
    • 99 Air
    So…we replaced the long motor before the service and there was a alternative sump plug that’s was not plugged. Filled that in with a blank and now no issues.
    • JayG80
      • Dec 2006
      • 230
      • Santa Fe, TX
      • 2007 Ski Nautique Sold 2002 Ski Nautique
      https://pcmengines.com/wp-content/up...e-Oil2.pd_.pdf
      • jmo
        • Mar 2006
        • 723
        • MA
        I hope the dealer refunded your money at a minimum from “servicing” your boat.
        2018 Ski Nautique 200 TE, H6
        • gary s
          • Mar 2015
          • 335
          • Algonquin IL
          You do realize that advisory is for GM based engines that have roller camshafts not 20+ year old engines never tested on those oils right? Those Gen 2 oils were developed to protect the catalytics from contamination.
          • JayG80
            • Dec 2006
            • 230
            • Santa Fe, TX
            I read it differently since they specifically call out the Ford GT40. This is a change from the SAE 40 VR1 I used in my GT40. Agree about Dexos is for GM based engines but that isn’t the whole bulletin.
            ***All model engines not found above, i.e. Ford GT40, 5.7L and 8.1L. These engines should continue to be serviced with the weight and formula oil found below.
            Recommended A.P.I. Classification & Viscosity
            Above 50 ̊F
            SAE 15W-40 “GF-4/SM”
            • gary s
              • Mar 2015
              • 335
              • Algonquin IL
              #21
              The bulletin does say "continue" which means no change- so technically the bulletin about Dexos does not apply to other engines only the ones with cats. It's an EPA thing.
              • sbaker
                • Apr 2021
                • 29
                • Denver, CO
                • '98 Air Nautique
                #22
                Looked through my records and over all my GT40 oil changes (Valvoline VR1 40W), I've averaged ~4.25 quarts over 7 changes. The fluxuation is definitely from a variety of factors when draining (temperature of oil, level ground, patience to let ALL the oil drain out of the line, etc) but I've never put more than 4.5 qts.
