Hole shot/low end acceleration issues with PCM 343 in 2008 SANTE 220
  • MPB777
    • Oct 2019
    • 3
    • Dallas
    • 2008 SANTE 220
    My third season with my 2008 SANTE 220 and I’m having two issues with my PCM 343 (530 hours):
    1. Hole shot acceleration is terrible right now vs. past or even earlier this season
    -doesn’t matter if I’m pulling wakeboarder, surfer, tube
    -ballast full or empty
    -runs great at mid-top end…good responsiveness and no performance loss
    -boat can be empty and it just doesn’t get out of the hole like it used to
    -have upgraded the prop 3 yrs ago… no change there
    -changed FCC filter and inline filter this past winter as part of winterization
    -run through at least 3 tanks of fuel (50 gallon tank) this season
    2. Motor will stall when in reverse when I first launch the boat
    -motor stutters and is hard to restart after it stalls
    -only does this after launching and using a bit of reverse throttle
    -anything than more than “reverse idle” will cause it to stutter/stammer/stall
    My closest Nautique dealer is a 2 hour drive each way and is backed up. Any ideas on where I could start to diagnose and address issue?
    Truly appreciate any advice and guidance the PN community can offer.
  • swatguy
    • 1668
    • Midwest/ Northern IL
    • 2008 SANTE 210
    When is last time you did cap , rotor , plugs and wires ?
    • MPB777
      • Oct 2019
      • 3
      • Dallas
      • 2008 SANTE 220
      Plugs and wires were supposedly changed in 2018, but I didn’t verify. I can definitely start there and see if it helps. Can’t be any harder than the changing steering cable I did this past winter.
      Thanks Swatguy!
      • pSchwade
        • May 2012
        • 130
        • Reno
        • 07' 220 SANTE
        If you haven't already changed the cap and rotor I highly suggest getting one with copper electrodes. Most are aluminum and develop surface oxidation rather quickly. I think I got my last one at summit.
        • MPB777
          • Oct 2019
          • 3
          • Dallas
          • 2008 SANTE 220
          Thanks pSchwade, need all the help I can get!
