Originally posted by Peter6000
View Post
Originally posted by gary s View PostIt is a standard (left hand) rotation engine, +1 on what Pete says a leak down will help. Say for example your rings are bad you would hear air out of say your oil cap,dip stick or pcv valve etc
Good info in case I do end up having to buy a short block. You guys rock!
If you have access to an engine hoist, I would pull the engine and strip it down to short block status and take it to a good reputable engine rebuilder in So Cal. Have the heads refreshed and slap that bad boy back in the boat.
jQ
Originally posted by Jonny Quest View PostIf you have access to an engine hoist, I would pull the engine and strip it down to short block status and take it to a good reputable engine rebuilder in So Cal. Have the heads refreshed and slap that bad boy back in the boat.
jQ
