Firing Order
  • Bazel
    • Jun 2020
    • 14
    • WI
    • 1990 Sport Nautique
    Firing Order
    Need advice on where #1 should go on Cap
  • core-rider
    • Feb 2004
    • 1361
    • Huntsville, AL
    • 2003 Black SANTE
    It would greatly help to know what model engine!
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • gary s
      • Mar 2015
      • 335
      • Algonquin IL
      Does not matter what model or even if it's a 4,6,8 cylinders. The rotor in the distributor always points to number 1 cylinder position when said cylinder is at top dead center on the compression stroke
      • Bazel
        • Jun 2020
        • 14
        • WI
        So are you saying if I took the cap off the point is pointing to should be #1? I appreciate the help
        • gary s
          • Mar 2015
          • 335
          • Algonquin IL
          Only if the number one cylinder is at top dead center on the compression stroke. Then you can remove the cap and check to see where the rotor is pointing,that terminal will be the #1 cylinder. https://www.autoblog.com/2016/03/25/...p-dead-center/
