Need advice on where #1 should go on Cap
Does not matter what model or even if it's a 4,6,8 cylinders. The rotor in the distributor always points to number 1 cylinder position when said cylinder is at top dead center on the compression stroke
Only if the number one cylinder is at top dead center on the compression stroke. Then you can remove the cap and check to see where the rotor is pointing,that terminal will be the #1 cylinder. https://www.autoblog.com/2016/03/25/...p-dead-center/
