Intermittent Starting Issue on 2015 SAN 210
  • jdavid484
    • May 2020
    • 3
    • Michigan
    • 2015 SAN 210
    I am having intermittent starting issues on my 2015 SAN 210. Today it started up initially without any issues. About 4 hours later it doesn't start. I had this same issue multiple times in the fall before I stored it for the winter, and it seems to be getting progressively worse.
    I have tried the suggestions mentioned in other threads with related issues but I have not had any success finding the root cause.
    • Voltage: Battery Voltage reading 12.0V on the Linc Screen, new batteries that were just pulled from a trickle charger, ground wires and terminals were cleaned
    • Fuel: When I press the start button I can hear the fuel system cycle
    • Starter: Cannot hear the starter solenoid - I bench tested the relay and it is okay.
    • Kill Switch: When I toggle the kill switch I can hear the fuel system cycle
    • Neutral Safety Switch: I am unable to find it on the transmission like some other posts indicated - how can I test this?
    • Moisture: It seems to occur after a rain but I have not been able to find any signs of moisture.
    I don't know what else to do. Any guidance is appreciated, thank you.
  • XBIGPUN66
    • Oct 2012
    • 473
    • Lake Mendota
    • WI
    Check your battery connections
    Ian S
    • jdavid484
      • May 2020
      • 3
      • Michigan
      • 2015 SAN 210
      Thank you Ian. I checked the connections again and everything looked fine.
      I am thinking it is the starter solenoid, but when I went to go check the voltage from the realy to the solenoid it started. It is tough to troubleshoot when it is not consistent.
      Open to any other suggestions. I will continue to update if I am able to make progress.
      • jdavid484
        • May 2020
        • 3
        • Michigan
        • 2015 SAN 210
        Update: I believe it is the neutral safety switch. Below is the troubleshooting process I used.
        The other day it did not start. I then jumpered the two wires shown below and it started. This indicates the neutral safety switch is not working.
