It's a good time to put on new hoses if you can. To get the wire reinforced hoses off I use a small flat blade screw driver to help peel the hose away from the fitting and then twist left/right while pulling. Sometimes some heat from a heatgun helps too. Or a bit of WD40 if oriented the right way.
The pump reversal thing is something to check...it's basically the pump mounted upside down. Still spins the right way but the housing is backwards.
