Gt40 running at 180
  • SilentSeven
    • Feb 2014
    • 2241
    • Bellevue WA
    • 2004 Nautique 206
    It's a good time to put on new hoses if you can. To get the wire reinforced hoses off I use a small flat blade screw driver to help peel the hose away from the fitting and then twist left/right while pulling. Sometimes some heat from a heatgun helps too. Or a bit of WD40 if oriented the right way.
    The pump reversal thing is something to check...it's basically the pump mounted upside down. Still spins the right way but the housing is backwards.
    Bellevue WA
    • tmb
      • Mar 2004
      • 616
      • Midwest
      • '22 GS 22 ‘12 200
      Update - I checked downstream hoses from water pump and didn’t find anything clogging. Changed the impeller to ensure it was good. Disconnected hose from raw water pick up where it comes in from boat and started engine. My hand was sucked hard Onto end of hose. When I was removing hose from brass nozzle, the price with the arrow would rotate right/left. Could air be getting sucked in there? Or in so
      e crazy twist, could the **** temperature gauge not work correctly?
      any other suggestions out there?
      '18 SAN 210 Reef Blue/Admiral Blue Metal Flake
      '12 SAN 210 TE Black/Masters Blue
      '09 SAN 210 TE Black/Fury Red
      '08 Air 216 TE
      '02 Air 216
      '98 Sport Nautique
      '89 MC Prostar 190
      • tmb
        • Mar 2004
        • 616
        • Midwest
        • '22 GS 22 ‘12 200
        This is the piece that was swiveling
        '08 Air 216 TE
        '02 Air 216
        '98 Sport Nautique
        '89 MC Prostar 190
        • SilentSeven
          • Feb 2014
          • 2241
          • Bellevue WA
          • 2004 Nautique 206
          That looks like the fitting to the thru hull/ball valve. Yes, it that's loose, I would think that could be a problem.
          Edit: If you can't screw it tight and maintain angles, I might apply a good bit of pipe tape in an attempt to seal it.
          Sent from my Pixel 3a using Tapatalk
          Bellevue WA
          • Aaren22
            • Jun 2018
            • 59
            • Ohio
            • 2001 SAN
            Mine was running at 180 and I replaced the impeller and now it runs at 160....
            • kylant
              • May 2010
              • 561
              • Lake Tahoe
              #21
              try another thermostat.
              my brand new gs22 had a bad stat, the replacement was bad as well
              3rd one works they way it should
              • tmb
                • Mar 2004
                • 616
                • Midwest
                • '22 GS 22 ‘12 200
                #22
                I'm waiting for my buddy to bring up a temp gun so we can rule out thermostat/gauge before we pull the water pick up.
                My question is if we have to take apart the raw water pick up, do you try to loosen the lock nut at the hull or take apart each individual piece?
                Pic is located in post 15
                '08 Air 216 TE
                '02 Air 216
                '98 Sport Nautique
                '89 MC Prostar 190
                • SilentSeven
                  • Feb 2014
                  • 2241
                  • Bellevue WA
                  • 2004 Nautique 206
                  #23
                  I think you're asking about the thru-hull fittings in post 18? If I understand your question correctly, there should be no need to undo or remove the thru-hull fitting itself. I understood your post here to mean that there was looseness where one of the bronze fittings connected to the thru-hull. What is shown the picture (it's small, hard to see) appears to be a female to female elbow fitting that connects to the ballcock valve. I'm assuming your loose section is one side of the elbow connections....
                  Do I have this right?
                  Bellevue WA
                  • tmb
                    • Mar 2004
                    • 616
                    • Midwest
                    • '22 GS 22 ‘12 200
                    #24
                    Yes, it’s the brass fitting just below the elbow. The arrow is actually pointing right at it. I didn’t know if it would be easier to disconnect at the base VS taking each part off individually. There isn’t room to turn the entire piece.
                    '08 Air 216 TE
                    '02 Air 216
                    '98 Sport Nautique
                    '89 MC Prostar 190
                    • SilentSeven
                      • Feb 2014
                      • 2241
                      • Bellevue WA
                      • 2004 Nautique 206
                      #25
                      Still not certain what's loose. The strainer thru hull fitting looks like this:
                      https://www.ebay.com/itm/Groco-1-1-2...p2047675.l2557
                      If the nut to the hull is loose, that won't cause an air leak. If one of the fittings that screws onto the thru hull is loose, that could be a problem.
                      Bellevue WA
                      • tmb
                        • Mar 2004
                        • 616
                        • Midwest
                        • '22 GS 22 ‘12 200
                        #26
                        The thru hull fitting is tight and fine. It's the elbow that connects to the thru hull that is loose on the thru hull side, not the side going to the strainer.
                        '08 Air 216 TE
                        '02 Air 216
                        '98 Sport Nautique
                        '89 MC Prostar 190
                        • SilentSeven
                          • Feb 2014
                          • 2241
                          • Bellevue WA
                          • 2004 Nautique 206
                          #27
                          yeeeah....I guess you'll have to decide if the effort to get in there an tighten it up is worth it. If it's loose, it could very well be an air leak and affecting your water draw.
                          If it were me and it looked really hard to tighten those joints, I might look at maybe trying to put some putty/sealant/something around the joint as a down and dirty test.
                          Then, if the problem improved, you can feel good about stripping it apart for a permanent fix. Of course, the test is only as good as the hack.
                          Bellevue WA
