Project time! Giving life back to my teak swim deck of an ‘01 SAN. Have the Starbrite 3-step kit, seems to do the job by most people’s accounts. But the teak needs some love first. Recommendations on sandpaper grit, approach, tactics to use? Thx!
Did someone stain the teak? I’m normally against sanding. No matter what grit you use it will be too slick. But if that’s stain or paint I think it’s your only option. 80 maybe then a 120 is what I’d probably go with. Get that off of there and then use a nice teak oil. It’ll take a lot of coats this year but if you clean it thoroughly now and keep teak oil on it you can do a light coat every few months going forward.
Yep. Spend a couple of hours sanding that down, then just hit it with teak oil. Don't bother with the three-step kits. Sanding and oiling is what I always do, and the results are always great.
Here's the last one I did (on my recently-sold 1999 SNOB).
NautiqueJeff Interesting. It looks great! So skip the three-step and just hit it with oil? What brand did you use for that teak deck in the pictures? How often do you re-apply?
Yep, just sand and oil. Those three-step kits are a waste of time. They take forever, and don't work nearly as well as just sanding and oiling. Should last quite a while.
I use Starbrite teak oil. I do a lot of these, so I buy it by the gallon on Amazon.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Jeff - do you prefer brush or wiping on with a rag?Originally posted by NautiqueJeff View PostYep, just sand and oil. Those three-step kits are a waste of time. They take forever, and don't work nearly as well as just sanding and oiling. Should last quite a while.
I use a rag. I usually end up applying about ten coats. Apply one and give it time to soak in, then apply another.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Hey all,
just in the process or redoing our teak deck. Previously it had a "aqua deck" product on it and was slippery and didn't look great.
I applied this product from the local paint store and then used a paint scraper to remove the old decking oil.
This is where its at now, dry and then washed down with water
Just wondering if I put teak oil on it now if it will take in all areas as some low spots that still have some decking oil.
Other option is to put more of the remover on there & scrub it out rather than just a scraper which I used the first time.
Cheers
Robbo
I've had problems in the past with swimstep's being super slick.
The boat dealer did the last refinish and it wasn't slick at all. But it needs a full refresh now.
I'm thinking of using a stripper to remove the old material and then a teak brightener to clean it up.
Any idea what grit I should use to rough up the surface to get a non-slick surface?2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
I use 80. Just sand it until you get to bare wood and add teak oil. Don't bother with the other stuff.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
I normally don’t use any sandpaper. It seems like any grit makes the surface more slick than I’d like it. I use a hard bristle brush and TSP. I’d only use sandpaper if I were trying to remove a previous owner’s mistake.
