2000 pro air with GT40. The bilge is working because when I Unhook it and plug it into the ballast wire and hit fill on the pad it cuts on for 2sec like it supposed to to check if water is present. My pump is automatic. No float switch. It checks every 5 min for water via different amp draw. If the draw is diff then it will run for a while.
Ok to the key pad. It’s BRAND NEW today. Got it in the mail thinking it was the pad. That was a $421 mistake. So when I hit the bilge button the pad, the green light cuts on and I hear a small tick under the dash at the PME breaker box Just like when I hit any other button.
My handheld meter also measures continuity by alarm and the bilge plug has continuity but when I switch it over to volts I get nothing. Also, all the breakers under the helm are good shape and not tripped.
Does anyone have the slightest idea of what I can check next.? Yes I can run the bilge off of the ballast wire just fine but it will only run the front pump and I spent 8 hours putting a new pump in the rear back in March and I just want everything to run like it’s supposed to. Dropped a load on this thing and it was all I could afford. Nice boat but I am certainly Busting Out Another Thousand quiet frequently lol
Thanks again guys!
Thanks again guys!
