Friday I’m picking up a new-to-me 2011 230. It only has factory ballast so I’m already planning to add some aftermarket weight. I have 2 x 800lb bags that should will fit in the rear, a 650lb ski locker bag that I think will work, and the parts to run a piggyback system. I’m concerned about LINC v1 and getting my ballast right. From what I’ve read I can’t adjust the system to make it fill or drain longer. Is there really no way to do that? If not, how do I fill the aftermarket bags? Do I just tell it to fill again after it hits 100%? Do I need to run some sort of bypass to physical switches to get the piggybacks full? This will probably make more sense when I’m in front of the boat but I’d like to make sure there’s nothing else I need so I can do this install without having to go back for additional parts on Friday.
And FWIW, I’ve done a ground up ballast install on my Super Sport so I understand the plumbing. I also understand the basics the piggyback method of using check valves to fill the soft bag and still prevent the tank from collapsing on drain. It’s just the LINC part of the equation (and timers in general) that are new to me. I’d also like to eventually get rid of the rear hard tanks and run larger bags in the back but for day 1 I’ll run what I have. Are there and LINC-related concerns with getting rid of the tanks? I know on the older systems the ballast gauges would stop working but LINC doesn’t have the same gauges.
