ZR6 normal temp operating range?
  • Jbousman88
    • Oct 2018
    • 54
    • Indiana
    • 2007 Super Air Nautique 220 w/ 6.0 ZR6 PCM
    Have a new impeller but my gauge always sits a tick below 175. I know the Tstat is 160. I’m coming from boats that normally do not run that high.
  • charlesml3
    • Jan 2008
    • 2482
    • Lake Gaston, NC
    • 2022 G23
    Mine usually stays right around 170. I don't think that 5 degrees more you're seeing is significant.
    -Charles
    • SatherG230
      • May 2018
      • 87
      • MN
      • 2012 SANTE 230 w/ NSS
      I agree with charlesml3 in that this is probably normal for your engine. My 6.0 ZR450 stays right at 172 if I remember correctly. (Only time I really make note of the specific degree is when winterizing it and waiting for it to get up to temp...)
      • Jbousman88
        • Oct 2018
        • 54
        • Indiana
        SatherG230 I figured it would be normal but I wanted to check. I have noticed some heavy white smoke/vapor at times when surfing. From what I can find it appears this has been a frequent asked question before. It appears more like water vapor and does not smell like oil. Also the two times it was heavy was after a big temperature drop from a storm.
        • charlesml3
          • Jan 2008
          • 2482
          • Lake Gaston, NC
          • 2022 G23
          Yep. It's steam and it condenses much more when it's cooler out. The G23 I surf behind regularly is from 2013 and doesn't have a surf pipe. It steams a LOT when it's cooler out.
          -Charles
          • tdc_worm
            • Feb 2004
            • 535
            whats your coolant mixture? if its more than 50:50 it can cause the closed cooling system to run hot
            • Jbousman88
              • Oct 2018
              • 54
              • Indiana
              Charlesml3 like enough to look like a fog machine? There was a old page on here from Skier12 that was excessive white smoke that was exact same amount as me
              • charlesml3
                • Jan 2008
                • 2482
                • Lake Gaston, NC
                • 2022 G23
                Yep. Especially in the Spring and in the Fall. If it's only doing that when the temperatures are cool, it's nothing to worry about. You only start getting concerned when there's white smoke all the time...
                -Charles
                • Jbousman88
                  • Oct 2018
                  • 54
                  • Indiana
                  Then I would guess we would be looking at a head gasket or loosing some coolant.
                  • d_nodixon
                    • Sep 2008
                    • 475
                    • Hammond, LA
                    • 2013 SAN 230
                    I run at 172 pretty consistentlyin my 2013, my prev 06 ran around 165
                    Sent from my Pixel 2 using Tapatalk
                    2013 SAN 230
                    2006 SSN 210 (SOLD)
                    • J9015
                      • Jan 2019
                      • 4
                      • Dallas
                      My 236 with ZR6 runs consistently at 165. Slightly higher at speed...170ish then.
                      • ally505
                        • Feb 2012
                        • 180
                        • Somewhere cold and wet
                        390 zr6, usually runs around 165, high load for a sustained period it goes up to 173. Due a new impeller soon so will be interesting to see if that changes things. Closed cooling too so as mentioned above the antifreeze may have something to do with it.
