Neutral Lockout
  • Chaabo
    • Nov 2019
    • 10
    • Clermont, FL
    • 2018 Ski Nautique 200 CB
    jmo
    I think I have to replace my throttle base assembly as well.
    My 2018 just developed the intermittent no crank issue.
    Neutral lock out switch isn’t working for a while now, but that never bothered me.
    But since this week the boat is almost impossible to start. It’s total random if she wants to crank or not.
    Could you please let me know which part # you ordered that worked for you?
    Nautique Parts sells #170156 but it sais “fits 2015 and up 210’s, 230’s, G-SERIES, AND GS-SERIES BOATS”
    Miami Ski Nautique has #170158 for “ski and sport 200”
    They look identical, but with electronics you never know.
    Thanks a bunch!
    David
    • jmo
      • Mar 2006
      • 730
      • MA
      Chaabo - I got the one from Nautique parts, it’s the same component for all Nautiques. My original base assembly said “200” on it but my replacement had the GS markings on it.
      2018 Ski Nautique 200 TE, H6
      • Chaabo
        • Nov 2019
        • 10
        • Clermont, FL
        Perfect, thanks a lot!!!
        • Waveslayer
          • Oct 2022
          • 73
          • CA
          • Mastercraft X9, G23
          I am resurrecting this thread. I have a 2015 G23 that is experiencing the same issue of the Neutral Lockout isn't functioning. Is there a long term effect, it doesn't bother me, should I just ignore it or replace it with the $600 part?
          • aerojust
            • Jul 2020
            • 66
            • VA
            • 2020 SAN 230 Past 2000 Ski Nautique TSC1
            Personally, I see no reason to "rev" a modern EFI engine. We use it all the time to start my brother in laws 84 2001. My 2020 230 had the same issue, and then it would start to not sense neutral and then not turn the engine over without a lot of jiggling the throttle back and forth. If your boat starts to do this I would replace the throttle base.This could leave you sitting with no way to start.
            • Scooter G
              • Jan 2022
              • 1487
              • On a Lake in Idaho
              • 2022 G23 ZZ8
              #21
              Ditto, mine doesn't work either. I thought I was holding my mouth wrong at 1st.
              For $600 I think I will probably wait until I start seeing starting issues, and have to replace it anyways...
              • bturner
                • Jun 2019
                • 1756
                • MI
                • 2016 200 Sport Nautique
                #22
                Mine's still not working either. Keep thinking about replacing it but I somehow can't seem to get myself to spring for the cash yet. I have a small info display I fixed first, I think.
                • jmo
                  • Mar 2006
                  • 730
                  • MA
                  #23
                  Keep in mind it’s not a matter of if you base assembly is going to fail, it’s just a matter of when…
                  before I had isolated the root cause of my starting issues, I thought it was the battery, replaced it, skied late afternoon in the Spring (aka no one else out on the lake) skied 2 miles down from dock, shut the boat off to board, and it wouldn’t start. I got it going by jiggling it, but that was not a fun 5 minutes…
                  I don’t know what year the redesigned base assembly started being installed on new boats from the factory. NautiqueJeff, do you know?
                  • DocPhil
                    • Jan 2016
                    • 468
                    • Midwest
                    • 2016 G23; yamaha superjet
                    #24
                    Reviving this thread a bit and taking a look Scooter G thread about the base assembly. My neutral override button also doesn't work. I haven't had any other issues so far but the boat is pretty new to me. I noticed it when I was running the boat on the trailer in the yard today. I had a water running through it of course as the engine was running but my question is this....
                    As long as you have a water hookup is it harmful at all to put the boat in gear on the trailer? Any downside to that?
                    • bturner
                      • Jun 2019
                      • 1756
                      • MI
                      #25
                      I'll throw in on this one, on this cooler morning here in Canada..... I know from personal experience that with the older boats with a packing nut, this was definitely not a good idea and the the stuffing box would howl to let you know it. Water is used to lubricate the shaft/packing and running it without water to do so will quickly burn up the packing. New dripless boxes have water from the engine's cooling system (at least the last 2 I've owned have) to lubricate the shaft. That said, I don't know that I would do so intentionally and if so would not run it for more than a second or 2 for some kind of testing. In theory, it should be fine but whether that water is enough to safely run for anything more than a quick test, I personally wouldn't want to find out. That and there's the risk reward aspect to doing so, as in, I wouldn't want to risk it as fixing a burned up packing box is no fun task on an Inboard let alone a vDrive.
                      This is pretty much in line with what AI is saying on the Interweb.....
                      Inboard Dripless Packing Box
                      Running an inboard engine in gear out of the water with a dripless packing box requires careful attention to prevent damage. While dripless shaft seals are designed to eliminate water leakage, they still require water flow for cooling and lubrication. For mechanical dripless seals like the P.S.S. system, it is essential to "burp" the seal before operation after a haul-out to expel trapped air, which can cause the seal to overheat and fail. Running the engine in gear out of the water without proper water flow can lead to overheating and potential damage to the seal and shaft.
                      Some sources indicate that even with modern dripless systems, a small amount of water may be necessary for lubrication and to prevent overheating, especially during extended operation. Running the engine in gear out of the water without water flow can cause the seal to overheat, potentially leading to failure. Therefore, while it is possible to run the engine in gear out of the water with a dripless packing box, it should only be done briefly and with the assurance that the system is properly primed and water flow is established, such as by using a water hose or muffs. Always follow the manufacturer's guidelines for specific procedures and limitations.
                      • Rednucleus
                        • Jul 2022
                        • 249
                        • WA
                        #26
                        Running dry in gear is hard on the shaft cutless bearing as well
                        • DocPhil
                          • Jan 2016
                          • 468
                          • Midwest
                          #27
                          Makes sense. I ran it again today without putting it in gear and there is a good amount of water coming from the shaft and down it. So I imagine a quick check in and out of gear is fine but prolonged running wouldn't be good. Thanks!
                          • JayG80
                            • Dec 2006
                            • 252
                            • Santa Fe, TX
                            • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
                            #28
                            Looks like Livorsi will rebuild this switch https://livorsi.com/product-service/
                            Has anyone done this? What was the cost and turn time?
                            nevermind I found https://www.planetnautique.com/vb5/f...nd-replacement
                            • jmo
                              • Mar 2006
                              • 730
                              • MA
                              #29
                              JayG80 I had mine rebuilt, I believe it was $150.00 to rebuild. I don’t remember how long it took, but it was weeks…
                              I had already replaced mine with a new unit, but I had the old one repaired so I had a spare. Of course it looks like the spare isn’t needed with the design change.
