Gang,
I'd been meaning to ask my mechanic about this but it's tough to get his time. Today he called me and we had a good conversation about how the ballast tank pumps and timers work on these late-model boats. Here are the details:
- There are NO LEVEL SENSORS in the tanks. None. They were always inaccurate and problematic so Nautique abandoned them.
- There are timers which fill/drain as needed. There is no adjustment possible for the timers. The "Pro Ballast" option is only an ON/OFF toggle in the dealer's menu.
- There is a pressure sensor in each tank that registers when the tanks are FULL. There is no corresponding sensor for it to know when they're empty.
- Any user profile such as Back To Dock which empties the tanks will run the pumps until the timer runs out. This may or may not correspond exactly to the time the tanks actually empty. It's just a timer.
- If a pump is started manually and set to EMPTY (outside of a profile being selected) it will run until it's manually stopped. In other words, Manual operation of the pump does not honor the timer. It'll run until you stop it.
So here's what my mechanic recommends:
- When filling your tanks, let them run to overflow. If the pumps stop before then, restart them until they reach overflow and stop on their own. If the pumps never stop on their own, then something is wrong with the pressure sensors.
- When emptying your tanks, let the pumps run until they stop on their own due to the timers or they make "that sound." You all know what it is. If the gauges still show some water, ignore it. The next time you shut down and restart the LINC, they should be showing zero assuming you've selected a profile that sets the tank levels at zero.
- Try to avoid running the pumps dry. The impellers are pretty resilient, but running them dry will shorten their lives.
That's about it.
-Charles
That's about it.
-Charles
