How do you change these on a GT-40 motor? Also what kind of spark plugs do I use? How do you test the Fuel System pressure? I'm working on my hesitaion problem still?
RE: Fuel Pump Relay
I would call SKIDIM they can answer all of your questions and sell you the parts. www.skidim.comNautiqueless in San Diego
RE: Fuel Pump Relay
Grant fixed his idle die problem by cleaning the throttle body. The fuel pump relays are standard bosch cube relays available at any autoparts store. The GT-40 manual in the download section of this website has all the information you need plus it's a great manual.
