Fuel Pump Relay
  • 1998CanadaNautique
    • Jun 2006
    • 43
    Fuel Pump Relay
    How do you change these on a GT-40 motor? Also what kind of spark plugs do I use? How do you test the Fuel System pressure? I'm working on my hesitaion problem still?
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Fuel Pump Relay
    I would call SKIDIM they can answer all of your questions and sell you the parts. www.skidim.com
    Nautiqueless in San Diego
    • ToolBoy
      • Jul 2006
      • 22
      RE: Fuel Pump Relay
      1998CanadaNautique:
      Tell me about your "hesitation" problem. Jump into my post : "GT 40 engine cut-out problem" Sounds like we might be working on the same problem. Any luck on a fix? Did you call Skidim?
        • 2909
        • Current 2017 GS22
        RE: Fuel Pump Relay
        Grant fixed his idle die problem by cleaning the throttle body. The fuel pump relays are standard bosch cube relays available at any autoparts store. The GT-40 manual in the download section of this website has all the information you need plus it's a great manual.
