2011 SANTE 210 ZR409 (6.0L)
Check the bilge area under the motor real good with a light could be an oil leak from engine.2009 Super Air Nautique 210 TE
1989 Sport Nautique
You should not have oil coming out of that area. You likely have at least two issues. One the seal around your rudder port is leaky and the other you have some sort of oil leak from your engine or other fluid leak. Like Scooter and McCann said check in your bilge area. Get it clean and then put down paper towels down to see where it might be leaking from.
