Just bought a 2006 SV211 Team Edition and noticed that the tower was a bit shaky. After trying to tighten the Phillips head bolts at the 4 connection points on the boat, I noticed some of them just spin without actually tightening. I was able to pull one of the loose bolts out and it was broken. I'm not too sure which tower it is, but I'm curious to know if this is as simple as replacing the bolts, or is the as back-plate located inside of the sides where the tower connects to the boat that will be needing to be replaced. Can someone help explain what options i have.
I just removed a tower and reinstalled a tower on my 2004 SV211. Let me know of any more questions because I've seen ALL the bolt locations now
. Also, I'd make sure you have stainless nylock nuts on there to keep from loosening again.
Question for you all............I bought spacers last winter to replace....what looked like...old smashed spacers (looks rubber like)
The question is: The spacers I bought seem thick? 1/8th myb.......and hard plastic. They are the ones that fit the tower etc perfectly.....just seem different then what was on there.
Thanks
Dave
old ones were just rubber. new ones might be more like starboard or plastic.
SS nyloc nuts on all the tower bolts people.
Have a look into seadek or gator step. It'll give your boat a more updated look that's for sure. Dries out faster too, they may have a template for your boat.Originally posted by DJ Arwood View PostWhat about flooring like this for an 06 SV211? I've called around and apparently nobody can do it. Any suggestions? I'm wanting to get rid of the factory snap in carpets.2009 Super Air Nautique 210 TE
1989 Sport Nautique
