Hello All,
So I recently purchased a 2000 Pro Air Nautique. It has the PCM 5.0 H0 275HP engine. Owner was having issues with starting (spark, engine turns over, but no boom). I currently believe it might be a fuel delivery issue. After testing the kill switch works (found to be common issue), I found the following:
1. Fuel Pump Relays - One for the high pressure pump, one for the low. How do I test them? This could be the cheap fix.
2 x https://www.nautiqueparts.com/produc...p-tbi-r130012/
2. Low Pressure Pump - Only found a couple gas lines and a power cable (Currently disconnected, pic attached). I ran 12v power to this pump and got nothing.
https://www.nautiqueparts.com/produc...-pcm-ra080018/
3. High Pressure Pump - When I opened the Fuel Control Cell which has the pump in it, I found a mess. No filter, and the power cable was missing a lead (pics attached). So I believe I have 2 options.
1. Purchase a complete FCC from the link below.
https://www.nautiqueparts.com/produc...part-ra080031/
or
2. Purchase the following items and refresh the FCC I currently have.
https://www.nautiqueparts.com/produc...part-rp080026/
https://www.nautiqueparts.com/produc...trol-cell-fcc/
http://www.skidim.com/KIT-FCC-PASS-T...info/RF121085/
https://www.nautiqueparts.com/produc...pcm-ra080025a/
http://www.skidim.com/HOSE-KIT-FCC-H...info/RK045098/
What do you guys think? Let me know if there is anything I am missing.
- David
PS: Nautiqueparts also sells this complete retro kit (below), but I'm trying to narrow down the problem first.
https://www.nautiqueparts.com/product/retro-fcc-kit/
or
- David
