Location comes into play a little bit. If I was a newbie, I would stick to the manual.
I can do it the right way in under 15 minutes. So whatever time saved with the suck-up method is kind of a mute point. Plus, after sucking up the AF, you still need to remove the raw water impeller, drain the FCC and drain water strainer.
I'm not arguing the physics and agree that the AF will eventually displace the water, but there is going to be a certain amount of mixing involved first. I know that I sleep better at night knowing that I saw with my own eyes all of the water drained out.
I didn't have a v-drive with the GT40, but it only takes a few seconds to loosen a clamp and pull the hose off the the transmission cooler. I leave it unhooked during the winter. We certainly didn't have to do the "suck up" method. The v-drive also has a drain, should only take a minute at best to drain.
I never had a problem with the block plugs stripping/shearing. The brass plug shouldn't damage the block and if they start to wear, they are easy to replace.
