I put 750s on top of the hard tanks this spring. Also added a 300lb sack under the bow seats. My experience is that you won't need to fill the 750s to get a great wave. And, if you do, you will want more weight up front (additional bag, lead, or passengers).
I use the same bow sac that jondavis posted and it fills my 06 almost perfectly. Problem is the overflow vents are constantly getting air locked and I have to manually vent the bag or push it out/throw boat in reverse to get it to vent. When draining generally always have to disconnect the bow bag from the belly tank or the bag collapses and the tank can't empty without bending sender.
Anyone else run into this issue/have a fix? Have tried one way air checks and adding lines but generally they aren't sensitive enough to the suction that the jabsco pumps create.
In regards to the question at hand, just got back from cumberland and with 500 in the bow, 350 in belly, and then 10 people jammed in the main cabin, it was nice to have 750s in order to completely fill the starboard side only and level the boat. The wake is stupid big and vertical on the OG hull tho unless more bow weight is added.Last edited by rlwagens; 08-07-2017, 06:09 PM.
750's will fit. The straight line sumo 900's also fit on top of the tanks. . My suggestion would be ditch the tanks and add 1100's back there. Gain a crap ton of storage and still get to maximize ballast.
Are you looking to add more for boarding or surfing, both?????
i have the piggy back sac in my ski locker from wakemakers ,and 200lbs of pop bags I keep all the way tucked under the nose . I can wakeboard at 23.5 around 3/4 full in each 1100. And surf with both 1100's full.
I had had to ditch the factory team prop in lieu of the 1617 to get out of the hole with that setup for boarding.
Can you even fill 750s all the way full in a 210 when piggybacked on hard tanks? I had 600s in my 210 and they maxed out the rear lockers. I usually didn't even fill them all the way full because I was worried that they would rub on the gas strut hardware and get a hole.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
I was looking at doing this to my 2011 210. Two 400 sacs plus bow, are the results not good enough? Is that why you are looking to go up to 750?Originally posted by tmb
I have a bow sac under my front seats that is plumbed into belly ballast. I still seem to get a little bow rise when my 400's are filled on top of my factory tanks. Wasn't sure how bad it would be with 750's.
Sent from my VS995 using PLT Nautique mobile app
We have the same issue. We just disconnect the easiest line to get to in order to allow air to flow through the bag so it doesn't pancake the tank. It's a small issue but well worth it for the additional weight.Originally posted by rlwagensI use the same bow sac that jondavis posted and it fills my 06 almost perfectly. Problem is the overflow vents are constantly getting air locked and I have to manually vent the bag or push it out/throw boat in reverse to get it to vent. When draining generally always have to disconnect the bow bag from the belly tank or the bag collapses and the tank can't empty without bending sender.
I have the 400lb triangle bag from ronix. It does take up the whole bow but we don't usually have that many people with usOriginally posted by SupraFly View Post
Thanks for the info. It looks like it's an easy install. Not a lot of irreversible drilling...
I'd love to know what bow sac you have.
Does it take up a lot of the bow storage area?
I was actually in my boat last night trying to measure the sacs that are on top of my hard tanks and it appears they may be 750's. definitely not 400's. I don't fill them all the way when I'm surfing. It makes the wave too steep and creates a little bow rise. I typically surf with them half full and the belly plus fly high bow sac full. It throws a great wave.Originally posted by biggertanks View Post
I know there are some design differences on the hulls of the new boats compared to mine so I was sure which I should use. I will probably just stick with the 750's since that's what it looks like I have in my 2012.
'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
On my 08 210 I should have removed the tanks and gone with 750s on each side. I have the 400s and get tired of the lost storage space when full. I have found that less weight in back is better for a progressive wave and more weight in the bow. I have right at 300 # of LeadWake bags that I move around depending on where and how many people are on the boat.
Sent from my iPhone using PLT Nautique2008 210 SANTE
Ski locker ?Originally posted by cedarcreek216I have 750's and a tube sac in the ski locker, far from ruins anything.
That center area in floor ? Mine has tank in it
2015 210
Sent from my iPad using TapatalkCurrent Correct Craft Boat
Correct Craft Boats Owned
Just as an update on a detour we took earlier in the thread, I installed the $16 check valve from wakemakers with two tee fittings on my bow bag and it now fills and empties like a dream without any worry of my center take pancaking. I had a little water left over in my bow bag but I think that will be alleviated by changing my quick disconnect at the bag from an elbow to a straight fitting.
Do you have a picture of this configuration you could share?Originally posted by rlwagens View PostJust as an update on a detour we took earlier in the thread, I installed the $16 check valve from wakemakers with two tee fittings on my bow bag and it now fills and empties like a dream without any worry of my center take pancaking. I had a little water left over in my bow bag but I think that will be alleviated by changing my quick disconnect at the bag from an elbow to a straight fitting.
