Hey guys, was out surfing in our 2017 G23 today and in some rough water when the following error code appeared:
DTC 1325 Knock Retard at Limit
The engine went into idle from surf speed, then I took it out of gear. After that, everything seemed normal.
I am halfway through a tank of gas I get from the same place every time, so not sure it is a gas issue. Also seemed very random and not sure if it had to do with the rough water?
Does anyone know what that code means and is it a concern?
Thanks in advance for any advice/ideas and loving the boat so far!
