Knock sensor error code?
  • Skipdawg316
    • Sep 2014
    • 20
    Hey guys, was out surfing in our 2017 G23 today and in some rough water when the following error code appeared:
    DTC 1325 Knock Retard at Limit
    The engine went into idle from surf speed, then I took it out of gear. After that, everything seemed normal.
    I am halfway through a tank of gas I get from the same place every time, so not sure it is a gas issue. Also seemed very random and not sure if it had to do with the rough water?
    Does anyone know what that code means and is it a concern?
    Thanks in advance for any advice/ideas and loving the boat so far!
  • XBIGPUN66
    • Oct 2012
    • 477
    • Lake Mendota
    • WI
    Sounds like a fuel problem to me...
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
    • Skipdawg316
      • Sep 2014
      • 20
      Thanks. Still getting it and have varied the gas quite a bit, even going slightly higher octane.
      Heard you can get this error when the boat is "learning" a new octane level, but starting to think maybe a bad sensor.
      • wakeany1
        • May 2010
        • 64
        • Canada
        • 2017 G21 Team H6 2014 Super Air 210 Team 1996 Ski Nauitique 2003 Super
        I keep getting this message as well. It seems to be happening when I am at slower speeds but if I accelerate harder it does not appear? Never have I had this happen? I cannot get a hold of anyone at PCM either they will not phone my dealer back.
        • XBIGPUN66
          • Oct 2012
          • 477
          • Lake Mendota
          • WI
          We use premium fuel with no added ethanol. This should make a difference in how the timing will be adjusted by the ecu.
          Ian S
          • GMLIII
            • May 2013
            • 2821
            I get that error code if I go from regular non eth gas to premium mon with gas from time to time. I just hit ignore and go on with my business. It is the engine adjusting to the new octane levels
            • JJD
              • Jun 2016
              • 3
              • NY
              • 2016 G23
              Had same fault code on my 2016 G23. PCM provided firmware update for dealer to re-flash ECM.
