I have a Moeller Fake-A-Lake. I tried using it for the first time the other day. I was a little concerned that the plunger didn't seat flush against the hull because the brass water intake fitting is so large. I turned the water on and started the engine. Water started coming out of the prop shaft as it should, but after about 30 seconds there still was no water coming out of the exhaust. I was afraid that the engine wasn't getting water so I turned the engine off. Is this normal? Does it take a while for water to start coming out of the exhaust?
I'm interested in hearing what others are using to run their boats in the drive way? Is there a fake a lake with a larger plunger that will fit completely over the water intake so the plunger can seat flat against the hull?
