This is my first post, so please forgive me if I posted a redundant topic. The boat in question is an '03 Air Nautique 206 SE
First let me note that this is the first time of the year using the boat and never had this problem before. I previously had a problem with electrolysis causing the rudder and strut to oxidize. I brought the boat to a marina, and they grounded these parts stating that that would stop future oxidation. This was done at the end of the season, and I have not used it since.
Before heading out for the first time of the season I installed a new battery because the old one was bad. After hooking it up I still had no power. I noticed an inline 30 amp fuse directly after the battery that was blown. I replaced the fuse three times, hoping that it was a bad fuse (highly unlikely but I'm being optimistic at that point). Each time it's replaced, it pops immediately after installing it. After opening the battery compartment to install the battery I did notice the waterproof cover was not on the 30 amp fuse and it was sitting at the bottom of the hull. Could water have caused the fuse holder to go bad, or could water inside the fuse holder cause an arc popping the fuse this way?
Before tearing everything apart searching for the problem, I would love some input to save me some time.
