Which oil filter for 450HP engine?
  • agouge888
    • May 2012
    • 102
    • Tennessee
    • none
    Changed my oil last night...went with Rotella 15w40 regular oil and Mobile 1 Filter. Ready to ride again
    agouge888
    • Whitetail15
      • Apr 2010
      • 603
      • Unknown
      • 2016 G23 H6
      Jeff, any word on this. Surely you have over 20 hours on your boat, what oil was put in by dealer? H6 engine correct?
      2016 G23
      • RDT-G23
        • Jun 2017
        • 589
        • TEXAS
        I am quite mechanically inclined, and anal-retentive. As such, I don't allow others to change my oil. I am coming from a Cobalt/Volvo. The only way to extract the oil from that engine was via pump through the dipstick (which I detest). Please tell me I can change the oil in the H6 the old fashioned/redneck way, via drain plug... Is the the proper M1 oil filter the M1-301? My G23/H6 gets delivered Wednesday, so I'll figure it out soon, but am just curious... Thanks.
        • RDT-G23
          • Jun 2017
          • 589
          • TEXAS
          One more item, not to hi-jack the thread (but it appears that many are discussing oil on this thread as well)... What is the final answer for those who have been changing their own oil on suitable oil for the 2016/17 H6DI?
          • greggmck
            • Oct 2014
            • 796
            • Bellevue WA
            • 2023 Paragon G23
            I'm the same way! You can do this but only if the boat is out of the water. You will need to build an extension hose that connects to the drain hose because the current drain hose is not long enough to reach the drain plug. You can find the fittings and the hose at Home Depot and build an extension hose that screws into the factory drain hose to reach the drain plug. However you will need to let the engine drain over night (at least) because the oil will run very slowly with this length of hose. I tried it and it took over 12 hours to completely drain the oil (in the spring temp of 65 degrees). Expect faster for summer time.
            However I believe it is much more efficient to get an oil extractor and build a hose connection to connect from the oil extractor to the engine drain hose. This way you can pull the oil from the engine from the drain hose which is at the lowest point in the sump pan. This can be done while the boat is in the water too so the oil can be hot. I prefer this over using the dip stick extractors because the dip stick does not always guarantee reaching the bottom of the sump.
            Finally, there is an error in the engine manual oil specification. I researched this and contacted PCM for an answer. You can read the full tread here: https://www.planetnautique.com/vb5/f...-specification
            But here is the essence of the issue:
            Last night I posted my question on the PCM website. PCM responded this morning with the following statement:
            "We use and recommend the Shell Penzoil Rotella15w-40 which is available just about anywhere including Walmart, yes this is a highly recommended oil for Diesel engines as well as gasoline engines."
            They pointed me to Shell Rotella T4 since Shell Rotella T is no longer being produced.
            From the Shell Rotella T4 website:
            Manufacturer Information
            Formula Shell
            FormulaShell® MOTOR OIL is a motor oil formulated for improved fuel economy and to provide the engine protection and performance required by engine manufacturers. It is compatible with other conventional and synthetic oils. It exceeds all automobile and light truck warranty requirements for gasoline and turbocharged engines where an API SM and ILSAC GF-4 oil is recommended. Protects against wear, rust and corrosion, piston scuffing and combustion chamber deposits, high-temperature oxidation and valve train wear.
            Here is a link to the Shell Rotella T4 oil:
            http://rotella.shell.com/products/rotella-triple-protection.html
            http://www.oreillyauto.com/site/c/detail/SHE2/T15401/N0434.oap?ck=Search_N0434_SHE_-1_-1&mn=Shell&mc=SHE&pt=N0434&ppt=C0162
            PCM also suggested that Amsoil has a compatible synthetic oil yes they DO RECOMMEND Synthetics as well and provided this link:
            https://www.amsoil.com/shop/by-produ...ine-motor-oil/
            So for me this saga is closed!
            • RDT-G23
              • Jun 2017
              • 589
              • TEXAS
              #21
              Formula Shell
              Thank you for your help!
              • Evening Shade
                • Apr 2015
                • 1295
                #22
                Formula Shell
                Greg,
                Thank you so much for finally answering this question for us. I have used Shell Rotella for years in my boats. I'm glad to hear I've been doing the right thing.
                • greggmck
                  • Oct 2014
                  • 796
                  • Bellevue WA
                  • 2023 Paragon G23
                  #23
                  Greg,
                  Finally, I thought I would show pictures of my oil drain extension hose and the oil extractor that I configured to connect to the oil drain hose of the H6 engine. The extractor works great and takes about 30-40 min to change the oil ensuring I pull out every drop of used oil. The only downside is this particular extractor has a limit of 6 qts, so I can't pull all of the oil without stopping to empty the extractor tank (oil capacity is recommended to 7qts). But at the time I could not find a higher capacity oil extractor that would easily adapt to the fitting for connecting to the H6 engine oil drain hose.
                  Here is a link to the oil extractor: https://www.amazon.com/Powerbuilt-64...pd_sbs_263_3?_ encoding=UTF8&pd_rd_i=B00OCEGONC&pd_rd_r=69HTZ5WEN 08Q8EBT6ATZ&pd_rd_w=XohY2&pd_rd_wg=1JOMJ&psc=1&ref RID=69HTZ5WEN08Q8EBT6ATZ
ID:	526895Click image for larger version
                  Gregg
