New 2015 230 throwing Exhaust Temp Warning
  • Guntersville230
    • Aug 2015
    • 419
    • Guntersville, AL
    • 2015 SAN 230
    Just got a new 2015 230 with the 343 and it keeps throwing warning code "DTC1415: EMWT1 higher than expected stage 1" warnings. I read in previous post that this was a known issue back in 2012-13 but I was uncertain if anyone had a similar issue in a 2015? My engine temps were all ok, water intake/outlets/filter are not clogged, so i'm at a loss, other than a defective sensor? Any one else had this experience?
  • Crjcarr
    • Jan 2013
    • 12
    • San Francisco
    • 2012 210 SAN TE
    This happened with my '12 210 TE with the 343. It was a factory defect that PCM corrected by installing new manifold cooling. Same error code, though. The EMWT01 is 'exhaust manifold water temp' which means either the water in your manifold is too hot ( not cooling enough to, manifold is overheating) or the sensors *think* the manifold water temp is too hot... Either way, probably a PCM issue that your local dealer can look into under warranty.
    • Guntersville230
      • Aug 2015
      • 419
      • Guntersville, AL
      • 2015 SAN 230
      Thanks! Just a bummer its a brand new boat and already having issues....had a 98 Air from new until I traded on this boat (17yrs!!!) and never had a problem...had this boat a month and issues start.....sucks!
      • seveet
        • Oct 2014
        • 185
        • Muskegon, MI
        • 2015 SAN 230
        I had the same thing. I believe it was just a software update the dealership did to the link system when I had my first service.
        • Guntersville230
          • Aug 2015
          • 419
          • Guntersville, AL
          • 2015 SAN 230
          Was it a software update that fixed it OR a software update that caused it?
          • seveet
            • Oct 2014
            • 185
            • Muskegon, MI
            • 2015 SAN 230
            Fixed it.😀
            • Guntersville230
              • Aug 2015
              • 419
              • Guntersville, AL
              • 2015 SAN 230
              Thanks! My dealership just called me back and said the same thing. Appreciate you taking the time to help me out!
              • Guntersville230
                • Aug 2015
                • 419
                • Guntersville, AL
                • 2015 SAN 230
                Other 230 question, are you running the stock prop or change to the 1235?
                • mooseknuckles
                  • Aug 2014
                  • 13
                  • N↑ID
                  • 2015 SAN 230
                  I have had this same issue all summer. I too had the software updated by the dealer. The warning continued to appear consistently when the water temps were in the mid to upper 70's and the boat was being operated at a slow speed (7mph or less). When the warning came on, we would increase boat speed to improve cooling and then clear the warning. Now that the water temps are in the mid to low 60's, I have yet to see the warning.
                  • Guntersville230
                    • Aug 2015
                    • 419
                    • Guntersville, AL
                    • 2015 SAN 230
                    Once I'm able to make it down to the dealer to get it flashed I'll follow up with if it fixed the issue
                    • deelan
                      • Jul 2015
                      • 90
                      • Denton, TX
                      • 2015 SAN 210
                      It will fix it. My 2015 210 did the same thing. Dealer ship "reflashed" took 15 mins and hasn't done it again.
                      I thought the 1235 was stock on 2015 230? From what I understand if you are surfing/wakeboarding that's the prop you need for that boat.
                      • Guntersville230
                        • Aug 2015
                        • 419
                        • Guntersville, AL
                        • 2015 SAN 230
                        Honestly, I haven't checked the # on the prop yet. Its in dry storage now so I was going to check it the next time we go out and see what I have before I make any purchasing decisions.
                        • Guntersville230
                          • Aug 2015
                          • 419
                          • Guntersville, AL
                          • 2015 SAN 230
                          Old thread, but I received this letter in the mail.
Name:	PCM Letter.jpg
                          • markj
                            • Apr 2005
                            • 1194
                            • NorCal
                            I got the same one last week.
                            • Guntersville230
                              • Aug 2015
                              • 419
                              • Guntersville, AL
                              • 2015 SAN 230
                              Have you already gotten the problem fixed or do you still have to take it in?
