boat is in great shape now, looking to sell and upgrade
Boatnfly, did you r&r the complete rudder port or just the cracked play. I have a similar problem and am wondering how hard it is to remove the original and how hard to get a nice tight seal on a replacement
I replaced both the cracked plate and port, as I bought them together. But I don't think you need to worry about a tight seal. Use lots of 3M marine sealant and new packing. It'll be fine. Easy fix however I had to remove the port ballast tank and lay on my back squiggle in and squiggle out of there to reach everything. It was a good AB workout getting myself out. Don't forget to buy new SS wire to safety wire the top rudder nut to the steering arm (VERY IMPORTANT). I also went to Harbor freight and bought a extra large (cheap) channel lock for both removing the packing nut and replacing. Other than the awkward body position it really was an easy job.
You can get safety wire by using .041 Stainless Steel welding wire. I had some serious leaking going on as well. Repacked the rudder with GFO. Still leaked. This Spring I replaced the consumables in the PSS drip-less. Still leaked. I then noticed that ALL the hose clamps around the back half of the motor/V-drive were "loose". Tightened them all up and NO MORE LEAKS! Not the OP's problem. Just mine.
