Warning! Diagnostic message
  • stevelanders
    • Aug 2013
    • 7
    • Little Rock
    • 230
    So my 2015 G25 with 9 hours is in limp mode with this error message. Has anyone had this problem and know if there is a "field" fix. I have identified that it is a throttle control sensory the code(according to my dealer). I have tried all of the resets that they know of, full power down and undo the batteries as well as a throttle reset. Nothing has worked. First weekend out, 15 minutes into our boat ride.
  • seachicken27
    • Jan 2012
    • 291
    • Bristol, TN
    • 2015 G21 2014 210 2005 210 2013 G23 1989 Ski 1998 Super Sport 1990 Sp
    there is a glare on the screen. can you type what it says?
    • SANTE230OH
      • Apr 2013
      • 28
      • Orrville, Ohio
      • 2011 SANTE 230 2006 SV-211
      I had the same or similar issue with my 230 when it was new with less the 15 hours on it. We were on vacation 8 hours away from our dealer. Neither our dealer, PCM nor Nautique were aware of a field repair. Our issue was a throttle position Sensor and Nautique overnighted a new sensor to us at the vacation house. It corrected the issue and have not had a problem since.
      • stevelanders
        • Aug 2013
        • 7
        • Little Rock
        • 230
        DTC 2123 FPP1 voltage low
        SPN 91 FM1 4
        Sante, thanks for the heads up. Did you install it?
        • SANTE230OH
          • Apr 2013
          • 28
          • Orrville, Ohio
          Yes. The sensor that was causing my issue was easy to get to it was right on top of the engine, a few bolts and a plug. 10 minute job. Good luck. I know from experience how frustrating it is to have an issue with a new boat.
          • dougschmalz
            • Jul 2015
            • 7
            • Mound, Mn
            • 2006 Super Air 220
            Idle only mode
            • dougschmalz
              • Jul 2015
              • 7
              • Mound, Mn
              oops! posted that on accident
              • Laketexoma
                • Dec 2004
                • 464
                • Lake Texoma (Texas side)
                • 2025 G23
                I had a issue like yours. My throttle cable became disconnected there is a quick disconect behind the throttle housing. Just plugged it back in and it was fine. Just something to check on
                2016 G23 H6
                2014 G23 550
                2013 G23 450 (Great boat)
                2000 SAN ( Loved that boat)
