PCM 450 engine codes
  • agarabaghi
    • Aug 2013
    • 31
    • Maitland, FL
    Not sure what happened. We were just idling back and the display shows up a few errors and then the manifolds got really hot that the paint started to discolored...
    DTC 116: ECT Higher than expected stage 1
    DTC 217: ECT Higher than expected stage 2
    DTC 1413 EMWT2 voltage low
    DTC 1413 EMWT1 voltage low
    DTC 1415 EMWT1 higher than expected stage 1
    DTC 1416 EMWT2 higher than expected stage 1
    Aux temp 1 higher - most severe level
    Im obviously going to call the dealer on monday but what causes this? Seems like something that should be covered under warranty
  • vision
    • 530
    • NC
    • 2013 G23
    Overheating codes. When you get to stage 2 high levels, you are getting close to engine damage. Hopefully everything works out fine.
    • agarabaghi
      • Aug 2013
      • 31
      • Maitland, FL
      hopefully nothing serious happens ... we werent even riding or anything... was just idling around and went to head back to the dock and it flash that warning. We then idled in as it was in limp mode at this point...
      • vision
        • 530
        • NC
        • 2013 G23
        Probably be fine. Sounds like you caught it early.
        • thedude
          • Apr 2007
          • 451
          • SW PA
          Be sure to check the raw water intake scoop on the bottom of the boat often. I've found it's square shape is prone to collecting leaves/grass/whatever which can restrict water flow to the engine. This was a 2013 G23.
          • agarabaghi
            • Aug 2013
            • 31
            • Maitland, FL
            Pulled the boat out to take it to the dealer and sure enough the whole intake was covered in weeds / leafs... Cleaned it up and ran the boat for a while at riding speeds / wot / idle and the temps were fine! Thanks guys! Everything seems to run fine, gonna change the oil on it as it ran warm for a while.
            This boat has both the coolant loop and the raw water intake. What cools what, i have no found the description in the manual?
            • Paxdad
              • Mar 2013
              • 775
              • Cumming, GA
              • 2008 210 SANTE
              The water entering the intake on the bottom of the boat circulates around the closed coolant loop that contains the antifreeze solution.
              2008 210 SANTE
              • agarabaghi
                • Aug 2013
                • 31
                • Maitland, FL
                gotcha... thanks. Anyone know where the transmission cooler is? On the other boats we have its also a place to check for weed build up...
                • vision
                  • 530
                  • NC
                  • 2013 G23
                  Indmars have an external ransmission oil heat exchanger. But the newer pcm transmissions circulate water through a cooling jacket in the transmission, if I am recalling it correctly.
                  • agarabaghi
                    • Aug 2013
                    • 31
                    • Maitland, FL
                    ah.. then there is nothing to pop a hose off an clean like on the indmars?
                    • vision
                      • 530
                      • NC
                      • 2013 G23
                      Correct. Just the main inline raw water filter which is under the floor boards next to the batteries.
                      • agarabaghi
                        • Aug 2013
                        • 31
                        • Maitland, FL
                        Yup! thanks!
