Perfect pass display comes on and goes off intermittently
  • ScooterMcgavin
    • 1540
    • 2014 SAN 210 TE
    I have a 2006 SANTE and the perfect pass screen or display will work fine and be very sharp at times, then all of a sudden it will fade off or the info will be all scrambled and broken up then go completely off.it does this all the time. Sometimes when I go out it will be on sometimes off, the perfect pass always works even when display is off. If display is off I can still turn perfect pass on, here the beeps and it works, just no display, then sometimes it comes back on bright , sharp and looks good, works good. Just the display giving me problems. Anyone else had this happen? Figured I'd check with everyone before I sent it off to perfect pass to have them refurb it.
    1989 Sport Nautique
  • trip33
    • Nov 2010
    • 248
    • Odessa, FL
    I had the same issue in my 06 211. I upgraded to the Stargazer version of PP and swapped it in about 30 minutes. Plug and play. I was very happy with it.
    • ScooterMcgavin
      • 1540
      • 2014 SAN 210 TE
      And what did that cost you to do trip33?
      1989 Sport Nautique
      • trip33
        • Nov 2010
        • 248
        • Odessa, FL
        I believe it was around $700 for the new display and the GPS module.
        • d_nodixon
          • Sep 2008
          • 475
          • Hammond, LA
          • 2013 SAN 230
          Same problem here....works great even though sometimes the display does not.
          2013 SAN 230
          2006 SSN 210 (SOLD)
          • ScooterMcgavin
            • 1540
            • 2014 SAN 210 TE
            Does anyone know if you can send it back and have perfect pass fix the display? I've emailed them and waiting to hear back.
            Wondering if anyone has done this? I read somewhere in a forum you could
            1989 Sport Nautique
            • migs
              • Aug 2008
              • 704
              • San Mateo, CA
              • SAN 210 TE
              Happens to me once in a while just like that as well. Everything works fine, display just disappears. Prob 2-3 times a season at the most. When it does, I just turn off the boat & restart and its fine.
              Migs
              G21 - En route
              SAN 210 TE (Finally)
              06 Sky Supreme V220(previous)
              05 Sanger V210(previous)
              01 MC X1(previous)
              99 Air Warrior(previous)
              • BoardSkier
                • Jun 2014
                • 252
                • Lake Anna, Virginia
                • Air Nautique 226
                The same thing happened to my Stargazer display. I called PP. They Fed-ex me a new display with return Fed-ex envelope for the defective one. Didnt cost me a dime.
                2005 Air Nautique 226
                Supra Comp (prior)
                • ScooterMcgavin
                  • 1540
                  • 2014 SAN 210 TE
                  Ok called perfect pass and the update is... They discontinued the 2006 model in my boat back in 07, so they don't have that lcd screen to put in anymore. But he said he could send out a new gauge with a better screen and more robust design for 239.00 shipped to my house. Just an update for anyone else having this problem
                  1989 Sport Nautique
                  • BoardSkier
                    • Jun 2014
                    • 252
                    • Air Nautique 226
                    FIW - I replaced my 4" screen with the new 5" and a software update. It works really well. So I also have a 4" Stargazer screen if anyone is interested in it.
                    Supra Comp (prior)
                    • LakeBill
                      • Aug 2014
                      • 44
                      • North Carolina
                      • 2013 200V
                      Perfect pass has great customer support. I had a similar issue with a previous boat, they shipped me the new display with directions. Worked great. I highly recommend that company.
                      • laurie8888
                        • Dec 2011
                        • 162
                        • dubai
                        • nautique 206 and 200
                        if it is run off GPS then I had same problem, it is the GPS Antenna cable not the dispaly . I have one cable either side ( you only need one working) and disconnected one and the display is now fine
                        • jkallen21
                          • Jan 2013
                          • 400
                          • United States
                          • 2006 Super Air 220
                          Had the same issue and PP stood behind the product.Great guys.
