i have a 2001 ski nautique 196 with relatively low hours (340)...encountering a "sputtering" sensation yesterday when accelerating the throttle...starts, idles, and operates in slow speeds but once I "jump" the throttle, it "sputters"...any thoughts and/or direction would be greatly appreciated?
First thing to check:
The distributor cap. Take it off and look at the tabs inside. I bet they're all pitted and corroded. If they look rough, go ahead and replace both the cap and rotor at once. Not a bad idea to go ahead and replace the plug wires and plugs at the same time. They're not terribly expensive.
-Charles
You might clean the air strainer and check for water in the fuel system water catch (easy and free to do). It sounds most like lack of fuel which could get into needing guages to test pressure to see if you need to replace parts.Originally posted by oldschool1961 View Posti have a 2001 ski nautiqueKen
2001 DD Air GT40
thanks...fully agree and was looking to perform exactly that prior to kickoff of the 2015 season...do you by chance know as to whether or not a faulty cap, rotor, wires or plug would the "check engine" light to come and stay on?
thanks ken...just responded to another post and I'll ask you the same as I left something out of my original post. Would water in the fuel create a cause for the "check engine" light to stay on?
May be possible if lean fuel mixture sends a check engine code. That would really need to be hooked up to a code reader.Originally posted by oldschool1961 View Postthanks ken...just responded to another post and I'll ask you the same as I left something out of my original post. Would water in the fuel create a cause for the "check engine" light to stay on?Ken
2001 DD Air GT40
Just had the same problem and I replaced a lot in order to find the problem. It ended up being a combination of the alternator and fuel filter. The fuel filter was the main culprit as it still sputtered a little after I replaced the alternator. Your motor is a little different than mine as I have the pro boss. Check anti siphon valve and fuel filter .. 2 cheapest parts to replace.
Things I replaced to come to this conclusion....
Alternator
Hi and Low fuel pumps
Both relays
Spark Plugs
Wires
Dist cap
Button
