I am trying to replace my thermostat. There is a brass sleeve that appears to be press fit in the thermostat housing. It needs to be removed to get the thermostat out. Are there any tricks to remove the sleeve?
If I have a chance I will be replacing the t-stat in mine later this week so I will let you know if I run into the same issue and if so how I solve it. On the small block Fords I have done in the past there has never been a sleeve like that though.Shawn
2012 Blue Metal Flake SAN 230
That looks like it is upside down. I have never worked on the 502, but on my Excal, that whole housing would be flipped over and the stat would come off the top.
