On my 82 SN 2001, I'll turn the key and nothing will happen. I can keep turning the key and eventually it will fire. Now when I turn the key to off, sometimes the boat doesn't stop running. Is this an ignition switch problem and if so, who sells the part to fix it? Thanks in advance
RE: Ignition switch problem
It sounds like you have a worn out solenoid on your engine. Ford engines require a lot of juice to start correctly and if your battery is old or not fully charged it will wear out a solenoid and or your starter. Strange starting problems that act like gremlins can be caused by any weakness in the starting system. I have researched this personally because I had a similar problem with my '81 Ski Nautique. This should solve your problem.
