1.) How do the "A-B" switches work? The manual is a little vague. It says to switch the two daily. I'm assuming when the switch is "off", that battery does not get charged by the alternator right?
2.) Which battery is the accessory battery & which one is the starting battery? The rear battery has the amp leads on the '03, and I'm adding 2 more amps and 3 lights & wondering which battery I should connect them to. (I'm running 4 gauge to a distribution block for all 3 amps).
I'd like to use one battery as a backup starter (I guess--sounds logical), but I'm new to multiple batteries and was wondering what the "right" way is to set them up.
. My battery 1 is the primary starter, my second battery has my stereo hooked up. I will start the boat using battery one and then select "both" which will charge both batteries but they will also equalize if one is lower than the other. If I am going to just sit and listen to music -- well then switch to batt2. If you have a nautique with that bilge swtich connector - it is hard wired to battery1.
