In answer to some of your questions. The boat weighs about 3K so a single axle shouldn't be a problem. The arrow up and down on the key pad are for the electric rear seat back option. If you can lift the seat back up then you don't have the option. The gauges you need are Faria and it came in a kit. If you have perfect pass it is an easy swap with just a Y wiring harness plugged into the PP box. I wrote up a complete swap with pictures a few years back. Enjoy.
Your boat uses a 13 x 16 RH propeller. Common replacement is the Acme 422.
the up and down arrows by the keypad are used on Super Air boats only. The hatch was opened by an electric jack. Correct Craft used the same keypad in all the boat that model year, and thay are hooked up to nothing on your boat.
