Best Drill bit for Fiberglass?
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    I'm putting some pop-up cleats on the back for my Sport Nautique and they require a 1" hole to be cut through the gelcoat/fiberglass. What is the best bit to use? I have read in other forums to use a forstner bit. Also, I've seen a bullet bit recommended. Any thoughts?
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    I used a hole saw, in reverse through the gel, then forward to finish. Cover the area with blue tape before hand, and Sand the edges of the gel afterwards.
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      I think the reverse first is super helpful.
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        yep reverse... regular new sharp Dewalt style bits will work well...
        With such a big hole a smaller pilot hole first may help, both in reverse.... and chamfer/taper the holes afterwards so the load on the bolt is solely on fiberglass and not at all on gel... failure to do that puts load on the gel when those cleats are pulled on ...THAT will give you cracks.
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
        • swankster
          • Aug 2010
          • 1052
          • DFW, TX
          Thank for asking and posting this. I'll use this when I put the FAE on the G this weekend. Won't be one inch holes but still like the idea of reverse and taper.
          2010 SANTE 230 343 (280hrs)
          • mf01
            • Jun 2005
            • 515
            • Austin, TX
            Another question on the topic. Is the gunwale strong enough for the cleats?
            This is the cleat I plan to use. http://ecx.images-amazon.com/images/...oL._SX300_.jpg
            Previous:
            1994 Sport Nautique
            • s_kelley2000
              • 1575
              • Fort Meadow Recevoir
              • Mass
              Does your boat have any existing cleats? If so I would look at the backside of those if you can to determine if they used any backing plates or beefed up the fiberglass. To be safe it might be a good idea to use an aluminum backing plate or beef up the area with some mat and glass like you would for tower supports.
              Do you have a link for those cleats? I have been contemplating replacing my midship cleats with pull up ones and also adding a set near the stern of my boat.
              Shawn
              2012 Blue Metal Flake SAN 230
              • nyryan2001
                • Mar 2013
                • 1993
                • Lake Anna
                generally the strongest fiberglass will not be a big open panel of fiberglass... but near a corner, or near a bend... or perhaps 2 coners or bends like the top of a gunwhale, perhaps only 3-4" wide. Those corners and bends reinforce, and reduce flex.
                Those smaller spans of fiberglass will be stronger and have less flex under extreme loads... as compared to a huge wide open panel of FG, like the broadside of your boat for example.
                When you get into extreme applications... like adding an aftermarket tower, or lifting rings..... they are almost always near corner to reduce flex AND the backsides are reinforced with some type of backing plate to distribute the load over the largest area possible.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • mf01
                  • Jun 2005
                  • 515
                  • Austin, TX
                  http://www.amazon.com/attwood-AT-20-.../dp/B001O0DKMA
                  Previous:
                  1994 Sport Nautique
                  • TxJole
                    • Jun 2009
                    • 898
                    • Cedar Creek Lake TEXAS
                    I used oem Nautique cleat last year and they have a MUCH larger backing plate then Attwoods. I also use a new step bit to drill the holes, it bevels the gel coat for you.
                    • Pjoachim
                      • Apr 2013
                      • 124
                      • Wisconsin
                      • 2001 CB ski
                      What is a "Step bit"?
                      Wisconsin
                      2001 196 Ski Nautique
                      2013 200V Team Edition
                        • May 2025
                        Think of a step pyramid, just circular. Your local hardware store has them. They are not cheap, but they are worth it, especially when going through metal.
                        • TxJole
                          • Jun 2009
                          • 898
                          Step bit, my "go to" tool now.
                          http://www.lenoxtools.com/pages/Prod...tStepDrillBits
                          • mf01
                            • Jun 2005
                            • 515
                            • Austin, TX
                            Did you run the step bit in reverse?
                            You can get them at Harbor Freight. I have a few, but the largest is 3/4".
                            Previous:
                            1994 Sport Nautique
                            • TxJole
                              • Jun 2009
                              • 898
                              I start it in reverse then flip to forward. Key is slow and steady and let the bit cut.
