Wood replacement for Ram-Lin Single Axel Trailer
  • jguanciale
    • Aug 2009
    • 34
    • Bullhead City, AZ
    • 1982 Ski Supreme 1992 Ski Supreme 1996 Ski Nautique 2002 Ski Nautique
    Just happened to step on the side platform of my Ram-Lin trailer for a 2002 SN CB...despite the carpet looking almost brand new, I almost fell through the trailer. All of the wood is rotten. The bunks seem to be fine.Are there any templates available to make sizing easier and are there any wood substitutes that would make this the last time I have to change the boards/carpet? I attempted to contact Ramblin but got the standard "call your Nautique dealer" response.
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    Try using the old pieces for a template, and replace with diamond plate alum, or plywood coated with matching color bedliner.
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
      • 17233
      Agreed. The diamond plate works especially well. The wood just holds too much water.
      • AirTool
        • Sep 2007
        • 4049
        • Katy, Texas
        That's the biggest reason to not buy a ramlin trailer...I hate that policy. Now usually, they will give you a part number if you email ramlin@ramlin.com with the trailer vin. Then you contact your dealer with the part number...its like a triangle.
        • jguanciale
          • Aug 2009
          • 34
          • Bullhead City, AZ
          Thanks for the replies...considering diamond plate but worried about people busting *** climbing onto a wet trailer. Is it better to leave the metal bare or paint it the color of the trailer?
          • h20fun
            • Mar 2013
            • 19
            • eighty four,pa
            • 1977 Ski Tique sold 1984 Ski Supreme sold 1991 American Skier sold 2002 Sport Nautique
            I just redid the wood on my 2002 Ramlin trailer with outdoor plywood and coated it with Hurculiner bed liner. WOW does it look nice! And it won't stay wet for days after it get dunked. Ill try to get you some pictures. I used the old wood for a template. You will need one sheet (4'x8') of outdoor plywood. and one gallon of bed liner was more than enough. The whole project cost me about $130.00
            • AirTool
              • Sep 2007
              • 4049
              • Katy, Texas
              You know...that's something that should be done while the old boards are still good enough for templates. I'll check mine this year...trailer was put in service 7/2007.
              • s_kelley2000
                • 1595
                • Fort Meadow Recevoir
                • Mass
                Please post some pics when you get a chance. My boards are still solid but I'd like to upgrade at some point and was thinking diamond plate but I like the sound of what you did.
                Shawn
                2012 Blue Metal Flake SAN 230
                • obd666
                  • Feb 2010
                  • 793
                  • Bostian Heights, NC
                  • 03 SANTE
                  i redid mine in 3/4" king starboard and used the originals as the template also. that shape is pretty tough on the person doing the cutting (for a tandem axle anyway), so you'll need a pro to cut that out in diamond plate if you go that route ... yeah, i tried to get ramlin to sell me some pre-cut diamond plated steps like they put on some newer trailers but they claimed to no longer have the 03 patterns, haha
                  2003 SANTE - "OG 210"
                  • jmo
                    • Mar 2006
                    • 735
                    • MA
ID:	366100I redid the rotted out steps on my old trailer by using 3/4" AB quality plywood and sprayed it with linex, which worked great. You have to make sure the wood is super dry as the linex goes on hot and will evaporate moisture in the wood and cause bubbles, on one piece I had a knot that was still wet and they applying the linex had to redo that spot after hitting it with a torch to dry it out. If you go this route don't use pressure treated plywood as the chemicals keep the wood moist and will react with the linex coating.
                    To replicate the exact shape that was on my wishbone ram-lin trailer I would have needed an 4' x 10' sheet of plywood, so I instead made two sections and didn't bother with covering the space behind the wheel well, you can't step there anyways with the boat on the trailer. This way a standard 4 x 8 works.
                    The linex spray costs were higher than anticipated (maybe $250 in the end), they charge by the sq foot and since you have to spray both sides it adds up. It did come out great though, and wasn't too slippery when wet.
                    2018 Ski Nautique 200 TE, H6
                    • h20fun
                      • Mar 2013
                      • 19
                      • eighty four,pa
                      Pictures of mine redone with 3/4" plywood and Hurculiner.
                      • jguanciale
                        • Aug 2009
                        • 34
                        • Bullhead City, AZ
                        anyone using Trex reclaimed plastic then wrapping it in the carpet? also was told I couldn't use aluminum diamond plate...couldn't weld it to the steel trailer. Really didn't want to have to paint the steel
