Frustrated with my teak platform
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    My teak platform is slippery, especially after I "treat" it. I have read a few posts of people that suggest that it shouldn't be slippery. Whats your secret?
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
  • swc5150
    • 2240
    • Eau Claire, WI
    • MasterCraft Prostar
    I used to lightly wet sand between each coat of oil. I'm not sure if that was the key to making it less slippery, but it sure looked nice, and was easy to walk on.
    '08 196LE (previous)
    '07 196LE (previous)
    2 - '06 196SE's (previous)
    • s_kelley2000
      • 1589
      • Fort Meadow Recevoir
      • Mass
      dumb question, but wet sand with water right? I have wet sanded fiberglass to remove oxidation on my old Sport but just wanted to make sure it was the same process on a platform? What grit would you recommend? Mine is not slippery but it does not stay looking nice for very long after cleaning and re-teaking using the Star Bright products.
      Shawn
      2012 Blue Metal Flake SAN 230
      • swc5150
        • 2240
        • Eau Claire, WI
        Being that we have long winters here in WI, I had plenty of time to slowly oil my platform. Here's my method, and I know it'll be considered overkill by some. Obviously clean the platform and give it ample time to dry. You may want to dry sand your platform, if it's not smooth or has flaws you want to take out. The grit will depend on how beat up the wood is of course. Next: Apply a layer of oil to the top and sides; let dry. Flip and oil the bottom; let dry. Once dry, wet sand lightly with 1000 or 1200 grit. Let dry, and repeat each week until the wood is thoroughly penetrated with oil - basically it stops absorbing oil. You'll easily make it through an entire summer with a beautiful oiled platform. I'll try to post some pics of mine...
        • swc5150
          • 2240
          • Eau Claire, WI
ID:	365444Click image for larger version
          • swc5150
            • 2240
            • Eau Claire, WI
            BTW, Correct Craft put their thinking caps on when designing their platforms for easy maintenance. Refinishing a slotted MC platform (pre-EVO hull) is an awful experience!!
            • Miljack
              • Dec 2004
              • 1631
              • Charlotte, NC
              • '08 230 TE ZR6
              Wow, THAT's an oiled teak deck! Did you use any source of heat between oil coats? The "old salts" recommend doing it in the sun so the wood's grain opens up more...
              2008 230 TE-ZR6
              • s_kelley2000
                • 1589
                • Mass
                Thanks for the tips! Unfortunately I'm pretty sure I got at least another 6 weeks of winter up in MA so I have plenty of time to get my platform in ship shape.
                Shawn
                • shag
                  • 2217
                  I used to use a stiff brush and rinse first. Let dry for a day, then use a teak brightener (liberally) and then flush and let it dry again, then I use a wire brush (yes a wire brush) do get a fresh surface and open the pores up, rinse thoroughly and I mean with a flood of water (just take the nozzle off the hose) let it dry, then sometimes I would use the teak brightener again - let it dry, then lightly oil with a good quality teak oil. The key is letting it dry good each time and naturally / preferably in the sun. I owned a few teak boats, and I used this process about once a year maybe a little longer sometimes with good results.
                  • swc5150
                    • 2240
                    • Eau Claire, WI
                    Depending on the day here in WI, the best I could normally do is keep the garage at 70 degrees, while letting the warmth of the sun shine on it through a window.
                    Shag has great advice too. Brushing the wood is important in prepping for oil.
                      Many teak oil contain sealers. You do not want this. I use Meguire's teak oil, it is just oil.
                      To clean the platform, I use Dawn, and water, with a stiff nylon brush, while wiping the boat down after using it at the boat ramp. That is the most gentle cleaning method.
                      Two part cleaners are an acid, and a base, for neutralizing the acid. They can be hard on the metal parts.
                      The last resort is sanding the platform.
                      Once the platform is clean, I use the Meguire's oil, with bronze wool. Apply a coat, let sit, in the sun, apply a second coat, sit in the sun, repeat as necessary.
                      • jguanciale
                        • Aug 2009
                        • 34
                        • Bullhead City, AZ
                        • 1982 Ski Supreme 1992 Ski Supreme 1996 Ski Nautique 2002 Ski Nautique
                        How do I ship my platform to you guys?
                        • todda
                          • Jan 2005
                          • 283
                          • Granite Falls, WA
                          • 1999 SNOB
                          @swc5150, that has to be the best looking teak platform I have seen...better than mine! Way to go! Have you noticed any oil residue on the bottom of your ski or board? That is the only reason that I have used oil fairly sparingly.
                          Todd Aalbu
                          1999 SNOB
                          66.5" HO S2
                          • sodbuster88
                            • Nov 2008
                            • 368
                            • Clayton, NC
                            I'll second that. I had a couple of hose MC platforms an finally started sealing (mcguires teak sealer) them after oiling...
                            Peace..
                            • east tx skier
                              • Apr 2005
                              • 1561
                              • Tyler, TX
                              Every few years, I hit mine with about 120 grit and start from new. About 3 coats of Amazon golden teak oil, and it's looking great, and not to slick to use. As mentioned above, the wet sanding, fine piece of furniture method looks great, but is slick like glass. In between major resanding, I just hit it with a quick zero grade steel wool, dust it off, and apply a single coat of oil with the palm of my hand. Wipe off the excess with a rag and it's good to go for the next year. I spent about 15 minutes on it today. First picture is before I wiped off the excess.
