Steering on my '99 Sport Nautique is heavy, taking much more effort than other Ski & Sport Nautiques I've driven. It seems to be getting worse: it steers very hard to the right, and spins hard left if pressure is taken off the wheel. A mechanic said that the steering can't be improved. Any ideas would be appreciated.
A 99' should have a tunable rudder like in the pics below, you want to move it centered or just offset left for a neutral steering wheel.
If you do not have a tunable rudder grinding is your other option.
BTW, you may want to find another mechanic, lol
You might also change the packing in the rudder shaft. Its a 10 minute job if you dont have ballast tanks. It made some difference on my sport. You can also inspect the connections and lubricate the cable.
I agree with Quinner, time to find an inboard mechanic , dont take it to the pontoon guy again.
Quinner- I've been tuning on my rudder, and when I've moved the tab all the way to the left, I can get my 206 to have a right hand pull at 30mph and above. It steers like my buddy's malibu response lxi, which is one of the most fun boats to drive I've been in. I haven't had it in the course like that but will shortly.2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.org
Chexi, dan1166, Quinner, Lvnspeed, NCH2oSki-
Thanks for the great advice and especially the photos. Invaluable.
Have tunable rudder. I set it to the extreme to counteract hard steering when I got it in 2007. I'll change the cable, adjust the rudder and since I don't have the fat sacks, repack the rudder.
Appreciate the advice. Hope you're finding time, a third and flat water.
