Can steering be improved on '99 Sport Nautique?
  • RTSN
    • Mar 2007
    • 6
    • Minneapolis, MN
    • 1999 Sport Nautique
    Steering on my '99 Sport Nautique is heavy, taking much more effort than other Ski & Sport Nautiques I've driven. It seems to be getting worse: it steers very hard to the right, and spins hard left if pressure is taken off the wheel. A mechanic said that the steering can't be improved. Any ideas would be appreciated.
    • Jun 2026
    Maybe change the tuning on the rudder.
    • dan1166
      • Apr 2005
      • 92
      Definitely tune the rudder. Try to get the black insert more towards the middle of the rudder. This will make the steering more neutral. If your are not running the slalom course, I see no reason not to have the steering more neutral.
      Dan, the skier Man
      • Quinner
        • Apr 2004
        • 2246
        • Unknown
        • Correct Crafts
        A 99' should have a tunable rudder like in the pics below, you want to move it centered or just offset left for a neutral steering wheel.
        If you do not have a tunable rudder grinding is your other option.
        BTW, you may want to find another mechanic, lol
        • Lvnspeed
          • Aug 2008
          • 393
          • Smith Lake AL
          tune the rudder and replace the steering cable. I changed the cable on my 2000 and it made all the difference in the world.
          2003 226 LE
          • NCH2oSki
            • 1159
            • Maryville, TN
            • 2005 ski nautique 206 SE
            You might also change the packing in the rudder shaft. Its a 10 minute job if you dont have ballast tanks. It made some difference on my sport. You can also inspect the connections and lubricate the cable.
            I agree with Quinner, time to find an inboard mechanic , dont take it to the pontoon guy again.
            Quinner- I've been tuning on my rudder, and when I've moved the tab all the way to the left, I can get my 206 to have a right hand pull at 30mph and above. It steers like my buddy's malibu response lxi, which is one of the most fun boats to drive I've been in. I haven't had it in the course like that but will shortly.
            Prior Boats:
            1999 Ski Nautique GT-40
            www.skiersofknoxville.org
            • RTSN
              • Mar 2007
              • 6
              • Minneapolis, MN
              Chexi, dan1166, Quinner, Lvnspeed, NCH2oSki-
              Thanks for the great advice and especially the photos. Invaluable.
              Have tunable rudder. I set it to the extreme to counteract hard steering when I got it in 2007. I'll change the cable, adjust the rudder and since I don't have the fat sacks, repack the rudder.
              Appreciate the advice. Hope you're finding time, a third and flat water.
              • gtxragtop
                • Oct 2011
                • 56
                • Worcester
                I had difficulty turning my wheel to the right under power. Turns out the issue was that the lube on the rudder shaft was long gone causing binding.
                Pulled rudder and greased it with Mercury 2-4-C. Turns like it was new.
