Ballast pump placement on a 2002 SAN
  • youngunz
    • Mar 2011
    • 150
    • Barrie, ON
    • 2002 SAN
    Hello Everyone,
    Recently I purchased some new Johnson Impeller pumps to upgrade my stock ballast and I was looking for some advice on where others may have installed the pumps??
    I have two Johnson ultra ballast pumps that will be plumbed into two rear 750's. Any pictures or procedures of previous upgrades would be much appreciated.
    Thanks in advance,
    'youngunz
    2002 SANTE
    • Jun 2026
    I will take some pics and post today. Basically I pulled the flimsy carpeted divider between the seat and engine compartment and mounted the pumps on the bow side of the framing where the ski pylon is. Just barely fits.
    • youngunz
      • Mar 2011
      • 150
      • Barrie, ON
      • 2002 SAN
      That was my first thought as well..Look forward to seeing the pictures, Thanks!
      2002 SANTE
        • Jun 2026
        Here are two pics of my pumps. I cannot stress enough that they just barely fit (on my 2000 SAN). I have to say that God was with me when I installed these. I did made sure the seat back had enough clearance, but I did not double check the seat bottom frame. I had an "oh crap" moment when at first I could not get the frame back in. Then I found that I just had to do it a certain way. The factory aluminum cross beam was just tall enough to get 4 bolts in per pump. You have to measure carefully and account for the 90 degree bend in the bottom (i.e., you have to drill the top 2 holes closer to the edge than the bottom 2 holes, per pump).
        I have confirmed that there is no vibration in the seat back from these.
        For anyone else reading this thread, Jabscos might have too large a diameter to fit there.
        I really will try to do my write-up tomorrow of all of the lessons I learned the hard way.
          • Jun 2026
          Sorry about the first pic being upside down. It is right side up when I open it up on my computer.
          • youngunz
            • Mar 2011
            • 150
            • Barrie, ON
            • 2002 SAN
            Great pictures, thanks for the help!!
            2002 SANTE
            • thedude
              • Apr 2007
              • 451
              • SW PA
              I used the same pump on three different installs: a 2002, 2003, and 2004 SAN. What I did was made an 6"x12" aluminum plate out of .125" thick aluminum. I mounted that plate to the backside of the swim platform bolts and then mounted the pump to the plate on the port side. On the starboard side, I made the plate a bit wider to mount 2 pumps to it. It works great.
              Then I used the old carpeted material from the top of the ballast hard tanks to make a little swinging "door" which attaches the to engine divider with hinges. The purposes of this is to keep the bags from sliding back into the pumps when full. I will take pics and start a DIY thread shortly.
              • MI-Nick
                • Oct 2011
                • 54
                • Ypsilanti, MI
                i mounted mine to the glass behind the seat backs...plenty of room...plently strong...seat still fits fine...30 hrs and no issues yet...Click image for larger version
ID:	363892Click image for larger version
                • MAK
                  • Mar 2011
                  • 30
                  • Edmond OK
                  • currently mooching pulls
                  I'll post pictures of mine soon... I've got one under the seat that has the battery under it, one under the back bench seat behind the driver (far enough back I can put my batter jumper pack under that seat still, and then one mounted upside down in the center locker. Works good so far! I have them all wired to the dash with 3 rocker switches. Wake = AMAZING now.
                  • seth
                    • Jun 2008
                    • 549
                    • Santa Barbara, CA
                    • 01 SAN-sold
                    I cut out that plastic brace on the rear seat you can see in Chexi's pic to fit my pumps in that area. I was a little worried but cutting it out had no effect on the back seat. It doesnt bend at all when I lift it out.
                    • vanislwake
                      • Apr 2010
                      • 113
                      • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
                      i screwed mine directly to the floor under the rear corner seats i like that i can hear them a bit better there so i can tell when they run dry.
                      Current '02 sante full '06 updated
                      Previously owned:
                      07 San 210
                      05 Sante
                      03 Sante
                      01 San 210
                      02 Air nautique
                      00 Air nautique
                      + another 15 non nautiques
                      • ers906
                        • Feb 2010
                        • 921
                        • Phoenix AZ
                        +2 vanislwake. Pics to come
                        Eric, Phoenix AZ
                        G23 550 hp (finally here)
                        2002 Super Air
                          • Jun 2026
                          So fAR, I really like where I put mine. It might not be the easiest place to change an impeller on the two pointing down (not terrible either), but it is hidden and does not sacrifice any storage space or ease of engine access.
