I just put my boat in the water for the first time this year. Started up on the first push of the button. SHOrtly after come to realize I am having issues with my temperature guage. USually I am hovering around 140. Yesterday when at idle or just trolling I was above 180. If i plane the boat i notice the temp guage goes back down to about 140. This really doesnt make any sense here. Here is my issue, i took the boat in last winter to be winterized and had the mechanic change my water impeller. Maybe it was the wrong one... ALso i noticed that the 4 beside and above the pulleys that are about 1 - 2 inches diameter had no water in the them. THe water seemed to be pumping up to past my water strainer filter. I maybe wonder if these all have to be primed. When you change the impellar does it completely empty the water out of the tubes to the point it wont suck the water back unless primed ..
ALso my boat is smoking a lot more that usual. ITs not normal. The oils are all brand new and at the perfect level. I wondered if it was smoking from the impellar having no water ... Can someone please help me here.
Thanks CC Fans
Thanks CC Fans
