2011 SAN 230 TE with a Catanium CES 6.0L ZR409, has less than 37 engine hours.
Last Feb 18, my family & I were just going to cruise on the lake.
the boat was starting to accelerate when the engine suddenly just cut out (not sputtered out like it ran out of fuel).
1. I checked the on-board diagnostic tool of the Linc system repeatedly, it scans but there was no fault to be found.
2. Power was okay, batteries are full, All electricals are working fine.
3. fuel is full.
4. lanyard- i took it out & started it, wont even crank; reattached it, cranked, engine turned over but still no ignition.
5. fuel pump primes before cranking, pump can be heard running.
6. shift lever was shifted forward & reverse then back on neutral, the engine cranks with good power for a full 5 seconds but no ignition.
7. Ive also tried engaging throttle to 100% before starting but no difference.
8. I've gone as far as checking the starter, ignition relays & fuses and its all okay.
9. I've checked the spark plugs, they are clean but when tested for spark while grounded to body, there's no spark. will re-test. also with new ones but i think unless all 8 go bad at the same time that can make the engine stop working suddenly. I'm just not familiar with this engine system if they have a cdi module or the computerbox which doesn't give a current to the plugs.
other test i might do if advisable:
10. use a starting fluid to check if fuel pump is the problem.
11. check ignition coil if any
12. check crankshaft position sensor
13. check fuel pressure with a gauge
I've done everything i read in the pleasurecraft manual and on the internet.
I hope this is nothing serious.
also in contact with dealer for guidance.
please advice.
3. fuel is full.
please advice.
