Super Air 210 Tower Crack
  • Andy Mohler
    • Nov 2011
    • 18
    • Orlando, FL
    • 2010 Super Air Nautique coastal
    I'm a new owner of a slightly used (~30hrs )2010 Super Air 210. Went to check on her today in storage (outdoor) and found the base of the port side tower split/cracked with exposed metal ~2" long. No other marks. The tube looks a little bit bulged out at the base. I have no idea what could cause this. My initial thought was that somebody ran into me in the storage facility but it would have to be a really hard blow and there are no marks or dents. It recently froze here for one night ~30deg which is cold for Orlando. Ideas?
  • offshorejay
    • Aug 2010
    • 65
    • NJ
    • 1997 Ski Nautique 176 2021 Centurion Fi23
    looks like it froze to me
    • Andy Mohler
      • Nov 2011
      • 18
      • Orlando, FL
      man, how do these things survive up North? got to be a manufacturing defect...even my Orange tree did not freeze. I have a warranty and I hope this is covered
      • riderite
        • Jul 2010
        • 83
        Must of had some water in the tubing and when it froze it expanded and cracked..
        • mdvalant
          • Jan 2010
          • 155
          • IA
          • '90 Ski Nautique '00 Sport Nautique 75th
          What are we looking at? Looks like there's a few different random marks, can't tell if they are reflections or what.
          • mdvalant
            • Jan 2010
            • 155
            • IA
            Put a bottle of water outside at 30 all night and see if it freezes solid...water didn't cause this issue.
            • Andy Mohler
              • Nov 2011
              • 18
              • Orlando, FL
              you are looking at cracked, exposed, shiny metal. all the rest are just reflections. It looked like freeze damage to me also but I just could not believe it
              • TxJole
                • Jun 2009
                • 898
                • Cedar Creek Lake TEXAS
                It is a known problem my dealer here in Texas had a few replaced under warranty. I was going to put one on my 08 that cracked and was re-welded. All new towers have larger drain holes.
                • riderite
                  • Jul 2010
                  • 83
                  Just another reason to get a tower built out of stainless steel...
                  • HS
                    • Oct 2007
                    • 1333
                    • Sammamish, WA
                    • 2010 SANTE 210 (Sold)
                    Andy:
                    Is this the tower you have?
                    In what part of the country was your boat located when you noticed the crack?
                    http://planetnautique.com/vb3/showth...or-FCT3-Towers!
                    • HS
                      • Oct 2007
                      • 1333
                      • Sammamish, WA
                      Andy, does your photo show the damage at the tube ar in the gusset part of the tower? I think the recall (as I read it) pertained to the tube; in the photo, were pointing to the area where the weld joins the gusset plate and the tube??
                      • gride
                        • Jun 2007
                        • 1452
                        • War Eagle
                        • 05' 210 team
                        Is that a Roswell tower? My friends 09 cracked from freeze and Roswell came to his house and replaced it I believe. If not they fixed it.
                        • Andy Mohler
                          • Nov 2011
                          • 18
                          • Orlando, FL
                          thanks, it looks like the weep hole issue. This 2010 has always been a Central Florida boat. I'm just shocked that relatively mild cold weather could crack this. Sounds like I need to have my dealer fix this (Nautiques of Orlando)
                          • Andy Mohler
                            • Nov 2011
                            • 18
                            • Orlando, FL
                            it did not look like any damage in the gusset...it was the tube burst from inside. I grew up in N Ohio, used to seeing occasional pipes break at -20. Looked like those old galvanized steel pipes we had.
                            • RyanNoble
                              • Oct 2006
                              • 34
                              • Regina, Saskatchewan
                              • 1999 Ski Nautique GT40
                              30 degrees is just barely barely below zero and overnight that wouldn't cause enough expansion pressure to blow apart a tower tube. I would say until into the low twenties or high teens water wouldn't freeze hard enough to cause that kind of damage. I'd say its impact or stress related. Just my 2 cents.
