V Drive & Transmission Oil Change
  • Chopper
    • Jul 2004
    • 92
    • Brisbane Australia
    • 1989 Ski Nautique SN2001 1991 Ski Nautique 196 1998 Ski Nautique 196 2003 Super Air Nautique
    Hey guys.
    Having some difficulty changing out the oil in my V drive and son't want to have the same issue with the tranny.
    I have the Walter V drive / PCM trans combo in my 2003 SAN
    I have a vacuum pump setup that worked perfectly for the engine oil, but I've only been able to get around 200ml or so from the V Drive.
    I don't have a good seal against the dipstick tube and is is sucking air. Is this my issue.?
    I'm also not at the bottom of the housing by using the dip stick tube.
    I have done a bit of a search, but didn't turn anything up about this issue.
    Any ideas.?
  • TX-Foilhead
    • Mar 2009
    • 351
    • Kingsland TX
    There is a drain plug low and on the side. On mine the easiest way to get to it is to pull the floor. I've heard of people getting tubes stuck in the gears which required removing and splitting open the Vdrive to fix. That would waste any time you might save doing it from the top.
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      To empty the vdrive in my boat, I used to have to remove the floor and remove a plug on the backside of the unit. The oil would run out in the hull and out the bottom drain. What a pita and mess. I put a drain hose like the engine oil on the back of the unit in place of the plug. Now, floor stays in and I drop both hoses out of the bottom hole into a drain pan. I cannot get the vacuum pump into the sump of the vdrive because of the plumbing configuration of the oil fill itself. If there was only a way to drain the transmission without a vacuum pump, I would have it made.
      2005 SV-211
      • core-rider
        • Feb 2004
        • 1352
        • Huntsville, AL
        • 2003 Black SANTE
        I did something similar to ski4evr with mine. I thought I wrote a DIY thread on it but could not find it. I replaced the plug on the bottom side of the v-drive with a 90 degree hose barb fitting. I then attached some hose to that with a small shut-off valve. Now whenever I want to change the v-drive fluid I just attach vacuum pump to the valve, open it, and let it do the work. It made a mess the first time to install it, but from now on it's clean and easy.
        Jason
        All black 2003 SANTE
        -- Southern Fried --
        • TX-Foilhead
          • Mar 2009
          • 351
          • Kingsland TX
          That's a great idea, I'll have to add this to my list of tiny projects for the weekend.
          • EchoLodge
            • Jan 2004
            • 616
            • Huntington Beach, CA
            • 99 Super Sport
            Take some pics of your mod. After draining the oil you still need to clean the screen and the magnetic plugs but getting the oil out will make this much easier!
            Sent via Android!
            sigpic
            • EchoLodge
              • Jan 2004
              • 616
              • 99 Super Sport
              Pic
Name:	Walter vdrive.jpg
              sigpic
              • core-rider
                • Feb 2004
                • 1352
                • Huntsville, AL
                • 2003 Black SANTE
                Here are some pics... They were easy to get since my entire boat is torn apart right now for a stereo project I'm doing. Anyway, the little valve at the top of the pic is connected to a piece of black hose. That hose runs down to a 90 degree brass, barbed fitting. I had to get a 1/2 - 3/8 or 1/4 adapter can't remember what size to screw into the housing and then 90 degree fitting screws into it. True fully, I didn't look at the manual when I did the fluid change so I didn't know there was a magnetic plug or strainer, but the plug I'm draining from is the lowest point on the v-drive so once the fluid is drained you should have no problem puuling those without any fluid coming out.
                Guess I need to pull mine and make sure everything is okay.
                Jason
                • TxJole
                  • Jun 2009
                  • 898
                  • Cedar Creek Lake TEXAS
                  I like that set up but man lose that speed quik plastic valve. I been in the plumbing supply biz for 20+ years and i can tell you its not rated for those temps nor oil. Pm me and I will send you a valve for free. I'd hate to see that let go on you one day.
                  • EchoLodge
                    • Jan 2004
                    • 616
                    • 99 Super Sport
                    Tx foil if you do the install this weekend can you make a parts list for me?
                    sigpic
                    • core-rider
                      • Feb 2004
                      • 1352
                      • Huntsville, AL
                      • 2003 Black SANTE
                      I used it because it fit the tube of my oil pump. I kept the valve up high to keep the possibility of leaks to a minimum and make it easier to access. I'll PM you to see what kind of valve you had in mind.
                      Jason
                      • TX-Foilhead
                        • Mar 2009
                        • 351
                        • Kingsland TX
                        The weatherman missed the forecast today so no weekend boat projects for now. I've gotta have some sunshine to get motivated, I'll make a list when I get to it.
                        • johnboyy7
                          • Oct 2009
                          • 409
                          • houston
                          what oil is it to use in the vdrive? i found on here it just said 30w. does that mean just regular 30w oil?
                          04 SANTE 210
                          89 SPORT
                          • EchoLodge
                            • Jan 2004
                            • 616
                            • 99 Super Sport
                            http://www.dublerfamily.com/Regina_o...e%20Manual.PDF
                            OIL FILL
                            The V-Drive is shipped without oil and must be filled with recommended oil before
                            operation (See below). DO NOT USE SAE 80 MOTOR OIL, OR MULTI-GRADE
                            OILS SUCH AS 10W-30 OR 10W-40. Listed below are the approximate oil
                            capacities; actual quantity of oil required depends upon the angle of installation.
                            RECOMMENDED OILS:
                            SAE 30 Heavy Duty Motor Oil
                            Exxon Spartan EP-68 Gear Oil
                            APG-80 Gear Oil
                            sigpic
                            • johnboyy7
                              • Oct 2009
                              • 409
                              • houston
                              i saw some SAE 30 chainsaw oil. is this what you are talking about?
                              04 SANTE 210
                              89 SPORT
