As many people do, I have a problem with the prop guard dragging, especailly when getting into my garage. Essentially I have a low spot in the driveway about 4' short of the lip of the garage, and the prop guard hangs on it while backing in and drags while towing it out. For the last couple of years, I have placed a 2x10x8' in front of each wheel and used that to give me enough clearance to get over the lip. This is getting old, and I am finally serious about raising the trailer so I can back in without aligning the board, and so forth.
I have a 2000 air nautique on a Dorsey single axle trailer. From what I have read here are some options:
1) New Leaf Springs - I do think mine are sagging as the rear shackle is pointing toward the back and I have read that is a sign your springs have flattened a bit too much. if I go this route, how do I size the new ones - e.g., length, capacity, etc... Are the new ones going to sag within a few months anyway?
2) Longer Shackles - I have a shackle at the rear of each leaf srping that is about 3" - what if I went to a 4-5" shackles? It seems like this would be really easy, but what other problems would this cause? Misaling the axle slightly?
3) Spacer - a spacer between the spring and the axle seems eay enough, but I am thinking not the best way to go.
4) Prop Guard Wheels - I am likely going to add these in addition to one of the above - anyone have pics of a good setup?
Thanks in advance for any comments.
