Yesterday after pulling a number of rides, the boat sat for about an hour at the dock (no air flow in engine compartment so the engine compartment became quite warm (normal)). Boat started okay, but after pulling up the next skier and just after entering the course, it died (water temp, etc. normal). I didn't have my fuel pressure gauge with me so got towed back to the ramp and took the boat home. Several hours later I put a pressure gauge on it and it was fine (ran in in the driveway for 20 minutes at high idle with no problem but no load and engine cover was open so engine compartment didn't get hot). So I took it back to the course today to recreate. Sure enough, after pulling a few rides and letting it sit for a while (about an hour), I then started it and about 45 seconds later (about 4 ball), it died again. I put the gauge on, and there was no pressure. I checked, and both pumps were running (both making noise). After about 10 minutes with the engine cover open, I finally got pressure and it ran fine back to the dock and the ramp. I've never had any problems with the low pressure pump. About two years ago a pin hole developed in the hose attached to the high pressure pump, so slowly lost pressure. Replaced the hose, and it has been fine ever since.
Has anyone experienced this before? I'm ready to pull the canister, but because it ran fine and then suddenly starved, I'm almost wondering if the low pressure pump is having a problem when the engine compartment is hot, i.e.: it stops pumping, so the high pressure pump just pumps the gas in the canister until it runs out (which would explain it running halfway down the course before dying).
Because with the engine compartment open and it cooling down, I was not able to pull the output line off the low pressure pump to see if it was pumping, so don't know if it might be that.
I'd prefer it be in the canister, as it has been fairly easy to work with.
Anyway, anyone have any experience like this?
Thanks,
Gordon
Thanks,
Gordon
